about done with bmw's all together
  • custom e30
    • Nov 2009
    • 347
    just had new rod and main bearing put in and had all parts of my m20 inspected and came out fine,
    my new problems
    1. messed up on oil pan gasket and oil has been leakin for 3 month and new my low oil sensor comes on, so i add 2 courts of of the same oil i have always ran. 10w40 mobile, FULL SYNTHETIC
    2. about a hour later the oil pressure lite comes on and off severral time, when i rev up it goes off, but as soon ask car gets to temp, it stays on.
    3. oil goes a bit low so i decide to put some lucos [non synthetic] in to fix oil pressure problem and it does,
    4. engine is knocking and loud chatter,
    what the hell is going on????????????
    i do so much work and cant affored this shit anymore, somone tell me whats going on, cuz im about to junk the damn car
  • Inline Sex
    • Jul 2009
    • 346
    It sounds like a problem with your hydraulic fuel capacitor. Until you get it fixed, be very careful around left turns.
    Check my feedback HERE
      When the bearings were replaced was the crank shaft miked to see if worn out of tolerance? Then it should have had the journals plolished, miked again and the correct bearings picked to yield one tenth per inch of journal diameter. You should also have replaced the oil pump. The block should have had the oil passages rodded out, especially in the case of a previous bearing failure.
      • custom e30
        • Nov 2009
        • 347
        i didnt have any of tht done, but it was all inspected and was fine, any other ideas
        • VacMan
          • Apr 2007
          • 2405
          Buy a used complete M20 for a couple hundred bucks and save yourself the grief.
          • custom e30
            • Nov 2009
            • 347
            scrw it, iff it doesnt turn out to be something simple like not running synthetic like usuall then im getting out of bmw's, im not pulling the engine for a 3rd time i got a life to live. everytime i start getting some cash saved this thing fucks up
              Well, apparently everything wasn't as fine as it needs to be for new bearings to be a success. If the job had been done right, you wouldn't be having these problems now.
              Your choices now are to pull the motor and rebuild it correctly, or to find a good used motor and put it in.
              • Inline Sex
                • Jul 2009
                • 346
                Swapping in a used M20 will be a lot easier than whatever you did the first time
                • thereisnoyun
                  • Feb 2007
                  • 2301
                  this sounds liek a case of user error. If you dont follow the protocol or diagnose correctly or lack common sense. Every damn car will run to the ground when you try to fix it improperly.
                  • SpecM
                    • Oct 2005
                    • 4531
                    Dude, we went through this a few months ago
                    you didn't listen then, and your engine is still screwed up
                    1989 cirrisblau-metallic 325i
                    • custom e30
                      • Nov 2009
                      • 347
                      had a cerified shop diognos and repair, nothing wrong with that,we think the oil pump is bad
                      • Alpinweiße30
                        • Jun 2010
                        • 73
                        This
                          • 34827
                          sounds like you done broke it.
                          • custom e30
                            • Nov 2009
                            • 347
                            ok, shop is thinking, its something in the head, has anyone ever had problem or heard of engine making a knocking noise and it coming from head???????????
                            • Cabriolet
                              • 9620
                              only a blown head gasket have i head a knocking from the head. and that means you are over heating it... oil pump or hydraulic fuel capacitor. either way the more you drive it the more you are Fing up the engine.
                              Much wow
                              I hate 4 doors
