Can I put a 2.7 head on a 2.5 block?
  • testarosa
    • 10
    I have a '91 325i coupe that has a worn cam, it runs but I'd rather not have a cam failure to deal with if I can help it.
    A friend gave me a 2.7 head, complete. I am wondering if changing the valve springs would be all I needed to do to install it on the 2.5 block. I would use all the other 2.5 parts and ECU.
    This is a car for a special young driver, his first, and I want to do it right. I suppose I could put a swap for an 885 in the parts wanted section but a bird in the hand...
    Thanks for in advance for any help with this.
  • SpecM
    • Oct 2005
    • 4531
    Really doesn't work out
    I'm not sure if the valves and pistons would contact, but even if they wouldn't, the car would not run very well
    1989 cirrisblau-metallic 325i
    • dashboardmonkey
      FUCK YOUR WAFFLES
      • Jun 2008
      • 6158
      to put it simply.....NO!!!
      it will not work, the pistons will hit the head
      -Andy
        • 34837
        for the love of god no. rebuild the head, or drive it until it fails and swap in a new motor.
        • e30m20beast
          • Aug 2009
          • 176
          you can do it if it is a 88 super ETA head but it will not have the same power that you will have with the m20 head and it will probably missfire a lot, for the other heads they sell a spacer (like a really thick head gasket) to put it in between but I don't remember the company that does it.(sorry if I misspell something I am on my PS3 LOL)
          • Cabriolet
            • 9620
            No... and the 2.7 sucks compared to the 2.5 head
            Much wow
            I hate 4 doors
            • testarosa
              • 10
              thanks one and all, I didn't think it would work just needed to verify.
              I will scout around for an 885 head and do it right the first time.
              thanks again
              • dashboardmonkey
                FUCK YOUR WAFFLES
                • Jun 2008
                • 6158
                search next time, this question has been answered about a thousand times
                -Andy
                • bimmer_E30
                  • 5001
                  hai guyss can i put a m10 head on my 2.5 block? srs
                  Originally posted by e30e
                  • Kershaw
                    • 11822
                    at least you guys dont get cam or timing belt questions on a rotary forum....
                    thats a facepalm.
                    AWD > RWD
                    • hotballs
                      • 1155
                      I believe you can if you saw another one in half and weld it to the side of the complete m10 head.
