Eliminating the b*tch tube.??
    • 34839
    Originally posted by 20gmr
    Haha I relaxed some, so my apologies. And thank you I was under the impression that where the tube entered the IM it was being reburned I now see what you were saying with the port into the head. It seams silly that they would bother adding this tube because crankcase gasses can already flow between the head and block via the oil drains in the head. It will be deleted next time I remove the manifold
    that's because those holes for the oil drains are full of OIL
    deleting this tube would be a very bad idea, and I can't see a single reason why you would even want to do so.
    • 20gmr
      • 404
      Because eliminating it makes it's less likely to leak and easier too install the manifold. I also was un aware this tube was routing to the head, I thought it was going directly into the manifold to be reburned wich is what I was mostly trying to avoid. Now realizing the path of this air I understand eliminating it will not give me the desired outcome, because I have already gotten rid of the blow by air by venting the valve cover.
      As far as the oil drain back ports being full of OIL, i beleive you are wrong. If the oildrains were really that full I belleive the pan would go dry. Simply put the volume of oil draining back from the head is not that much. However this is just an educated guess.
      Dave @ Bimmerbuddies
      Contact Bimmerbuddies for all your Parts and service needs
      M20,24V,5spdSwap,Weld,Fab,Tow,Buy/Sell/Trade
      Bimmerbuddies LLC
      717-388-1256
      2971a Roundtop Rd, Middletown PA 17057
      *Ask about discounts for R3V members*
        • 34839
        how is it going to leak? it's two 5 cent o-rings. How often do you remove your IM? twice a week? in any case it's not hard to remove, all you have to do is push it down and zip tie the spring.
        yes, the oil drains are full - the M20 head actually has a problem at high RPM; the oil sprayer bar fills the head up with oil faster than it can be drained. MM solved it by designing a restricted oil sprayer bar to reduce the oil volume at high speed.
          • 37832
          Why do people have a problem with this tube exactly? I've done several with no issue.
          Classic BMW Specialists
          Grover Beach, CA
          www.BimmerHeads.com
          • slammin.e28
            שמע ישראל
            • 12054
            X2.
            Maybe if they had designed the motor more like the M30 there wouldn't be a tube there....or a timing belt for that matter...
            • bmwstephen
              • 2463
              would the manifold need to be removed in order to replace those 2 rings? I think mine is leaking
                • 34839
                you can replace the top one without removing the manifold, but the bottom one would be significantly harder.
                the manifold isn't *that* hard to remove - not as involved as say, swapping heads.
                • DaveSmed
                  • Apr 2007
                  • 1407
                  Fuck.
                  Is everyone from the east coast who owns an E30 retarded? I know a couple people personally who are OK, but with guys like this one, aquarium heater man, and a few others I'm starting to worry.
                  -Dave
                  2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
                  Need some help figuring out the ETM?
                  • 20gmr
                    • 404
                    I hope you wernt referring to me with that comment. For the record I have never removed the tube or manifold, so I have not struggled with it. I'd appreciate if you keep your keyboard ninja comments too yourself. I may be new here but I'm not new to forums or cars.
                    Bimmerbuddies LLC
                    717-388-1256
                    • Aerton
                      • Oct 2006
                      • 729
                      Filter in the valve cover
                      So my mechanic said if I vent the valve cover it would improve my chance of passing inspection as my car failed for like 20 or 40 points. Thinking of adding a small filter just to pass inspection. Any truth to this?
                      WTB-Strut Bar
                        • 34839
                        your valve cover is already vented into the throttle body. disconnecting that is probably just going to cause more blow-by and oil leaks.
                        • Cabriolet
                          • 9620
                          it would improve it by like 1-3 points. you need a valve job, new O2 or cat. don't waste the money on a pretty useless endeavor.
                          Much wow
                          I hate 4 doors
                          • Aerton
                            • Oct 2006
                            • 729
                            I hear you guys thanks.
                            WTB-Strut Bar
                            • Aerton
                              • Oct 2006
                              • 729
                              by valve job you mean adjustment? Any idea how much that cost?
                              by the way beautiful cabrio!!
                              WTB-Strut Bar
                              • Cabriolet
                                • 9620
                                i have no clue because i do it myself. but it's probably close to $150.
                                and thx
                                Much wow
                                I hate 4 doors
