Eliminating the b*tch tube.??
    • 37833
    #31
    A valve adjustment with gasket should be $100 or a little less.
    Grover Beach, California
    BimmerHeads.com
    • Wild Ride
      • Apr 2008
      • 739
      #32
      Originally posted by MR 325
      Why do people have a problem with this tube exactly? I've done several with no issue.
      I definitely struggled with it. It is a pain to get the spring loaded tube to avoid severing the o rings during install.
      • StereoInstaller1
        GAS
        • 22679
        #33
        use 2 wire ties as spring compressors, cut them off after installation.
        Closing SOON!
        Thanks for 10 years of fun!
          • 37833
          #34
          I've never even used zip ties. The trick is to use grease. The tube and spring will stay down.
          BimmerHeads.com
          • dclowd99011
            • Feb 2022
            • 11
            #35
            How do you use grease? Lube up the bottom and push the tube down?
            • Vincenze
              • Apr 2019
              • 1034
              #36
              The pressure of the spring is too high.
              Just use two small zip-ties.
              • dclowd99011
                • Feb 2022
                • 11
                #37
                Turns out my tube is dented so it was unable to actually go into the recess. I’ve ordered a new one so hopefully this will be much easier to deal with.
                • zaq123
                  • Jul 2016
                  • 1559
                  #38
                  that spring is not high tension by any means. One can definitely replace the top o-ring by just pressing down on the tube with one hand and put the o-ring with another. Zip-ties just make the job a little easier
                  • Vincenze
                    • Apr 2019
                    • 1034
                    #39
                    Generally, there is little space for manipulations as the intake is installed.
                    • moatilliatta
                      • 6152
                      #40
                      Installation and removal of "Bitch" tube should be a sticky.
                      I do wonder what would happen if you did delete it.
                      @Zakspeed_US
                      • digger
                        • Nov 2005
                        • 6182
                        #41
                        Not much would happen if you deleted it for normal driving on a stock healthy engine as the oil return holes are probably big enough to deal with blowby when you combine total area of them.
                        • moatilliatta
                          • 6152
                          #42
                          Think it does much for balancing crank case pressures or drain back from cylinder head?
                          @Zakspeed_US
                          • digger
                            • Nov 2005
                            • 6182
                            #43
                            Don’t think it does anything for balancing crank case pressure as it’s a single hole. It will let pressure escape easier in general but not from front to rear which is what balancing does . As for how much flow it depends on the engine condition and how you drive it may not be missed. From memory 1 cfm is about most blow by you’d expect
                            the oil that drains down it will find the next easiest way. I’d need to have a look to see how big of a pool it would make but I’d think it would not be significant.
                            I wouldn’t delete it personally as my engine is not a low rpm, low hp new engine.
                            im sure there are ways to improve it, better quality orings would be a start so they don’t go hard as fast. Perhaps additional preload on the o-ring would help
                            • hasa
                              • May 2013
                              • 307
                              #44
                              I have thought that the tube lets crank case pressure to enter head, whereas the holes at opposite side will drain oil back to pan. If crank case pressure should enter head only through drain holes, the drainage could be disturbed.
                              • Northern
                                I like cupcakes & sh!tboxes
                                • 5276
                                #45
                                I think it's just for airflow up to the head, since all blow-by has to get from the block to the head for the PCV hose.
                                Otherwise you have oil draining one way down the oil drains, and air moving the other way.
                                Might not cause drain issues, but might end up with more oil saturated air that comes out the PCV?
                                Originally posted by priapism
                                Originally posted by shameson
