Injector questions
  • Evan12
    • Dec 2010
    • 346
    Injector questions
    On a stock 87' 325is. what size are the injectors? i heard they are about 14.5lb injectors. is this correct? my question is, if i made the jump to 17lb or 19lb injectors with light mods (intake, maf conversion, and chip) would there be any harm? which would you reccomend?
  • Kershaw
    • 11822
    all 6 cylinder e30s are 14.5lb injectors.
    do whatever you can afford. but make sure you take care of maintenance before go spending $600 on a maf+chip conversion.
    when was the last time your timing belt was done?
    AWD > RWD
      • 37828
      17lb is the way to go on these engines.
      Classic BMW Specialists
      Grover Beach, CA
      www.BimmerHeads.com
      • bmw325csi
        • May 2007
        • 4045
        Im going 19lb as soon as my injector rebuild kit comes in the mail. Ill let you know as soon as I get em in. I also have a Maf kit, intake and tune.
        harry/harout
        • bmw325csi
          • May 2007
          • 4045
          What car comes with these
          harry/harout
          • Kershaw
            • 11822
            17.5 you mean?
            AWD > RWD
            • tinkerputzer
              • Jun 2008
              • 508
              Originally posted by Kershaw
              17.5 you mean?
              I think he's referring to 17 lb injectors found on M50's.
              I installed a set of 0-280-150-415 (from an M50) on my otherwise stock engine with factory chip and you can tell there is a bit of a difference.
              • Morrison
                • 430
                You can also get 17 lb Bosch design III (plastic bodied) injectors from a 1999 Mercury Cougar V6 I've recently found out.
                "I think we consider too much the good luck of the early bird and not enough the bad luck of the early worm."
                -Franklin D. Roosevelt
                • NigelStu
                  • 827
                  Do you have dyno data before and after?
                  Or at least 0-60 or 1/4 mile times?
                  Ben
                  Thelma-Louise, the '88is Chump Car - back to M20 power!
                  2014 ChumpCar Season Schedule!
                  April 5-6 Autobahn, IL - Sat: 1st! Sun: 3rd
                  May23-25 Watkins Glen, NY: 4th, 5th, 4th
                  October 4 PittRace Sprints: 2nd in C-class
                  October 18-19 NCM, Bowling Green KY: 2nd, 1st!
                  Nov 1-2 Watkins Glen - Chumpionship - 1st car to exit the race with significant body damage :(
                  Find us on FB! Schaut Speed Motorsports
                  • Evan12
                    • Dec 2010
                    • 346
                    thank you thatd be great.
                    • Evan12
                      • Dec 2010
                      • 346
                      recently. as well as all my hoses etc. this wont be for a while, i am just doinf some research before i spend the money.
                        • 34827
                        etas are 19#, B25s are 14.5#. don't know about setas.
                          Unless you've done something to significantly increase the mass flow through the engine, larger injectors aren't needed for an M20B25. If the fuel system is working correctly and the injectors are clean and flow at their design rate the engine can be tuned for a A/F ratio of 12.8:1, which is as rich as you'd want to go.
                          • Kershaw
                            • 11822
                            ^ jlevie dropping the knowledge again.
                            Originally posted by nando
                            etas are 19#
                            really? :o
                            AWD > RWD
                              • 34827
                              yes, 19# low impedance
