Stubborn valve cover leak
  • brian52555
    • 425
    So, about 6 months ago I changed the oil/plugs/ did a valve adjustment on my m20.
    I followed the bentley guide to a tee, but ended up with a slight oil leak from the valve cover afterwards (I used a brand new valve gasket from BMW). I'm thinking of doing another adjustment and throwing on a new gasket I've got lying around. Do you guys have any tips to avoid leaks? Should I throw some sealant along with the gasket this time?
    Thanks.
    When the gasket is changed you are also supposed to change the four rubber bungs that fit into the head. The bungs don't come with the gasket (they should) and you have to get them separately. Did you do that?
    • brian52555
      • 425
      damnit... no?
      On the plus side I bought a set of 4 along with the new valve gasket that I have waiting at home. I guess I'll throw them on with the gasket.
      • e30rapidic
        • 2167
        and a thin film of gasket sealant to be safe
        '87 325ic, powered by S50.
          If you have an OE or VR valve cover gasket there is no need for any sealant. And using sealant will just make the job more difficult in 10k when it is time to adjust the valves again.
          • riceh8r
            • Dec 2010
            • 133
            i've looked for the bungs, but realoem doesn't show them for my M20, and pelican doesn't either. only M42. wuz up ??
            • e30rapidic
              • 2167
              sorry but I disagree...a thin film, not a gooping.
              • brian52555
                • 425
                Anyone else have an opinion on using sealant or not between the gasket and the head?
                Also, I can't seem to find any FAQs regarding the 4 rubber plugs... I'll check my Bentley later but I'd be nice to find a DIY online with pictures etc.
                • Kershaw
                  • 11822
                  no sealant.
                  but i'd use a flat razor to make sure the edges of both the cylinder head and the valve cover is truly clean. make sure its absolutely smooth to the touch.
                  AWD > RWD
                  • SpecM
                    • Oct 2005
                    • 4531
                    hmmm I just looked at REAL OEM too trying to find the part# for you
                    but I didn't see it
                    but I know the parts are there... they are "rocker shaft plugs, x4" IIRC
                    1989 cirrisblau-metallic 325i
                    • brian52555
                      • 425
                      Yep... I think i have the right ones sitting at home in a box. Thanks for checking, appreciate it.
                      I was looking for any info on installing/removing the old ones... since I don't have my Bentley with me. I can't recall how they're positioned in the head.
                      • davem
                        • Jun 2010
                        • 705
                        Once you have the valve cover off just pull them off and put the new ones in, super easy. They're not hard to access or anything.
                        • CabrioPunk
                          • 1451
                          I got them NIB at home. Ill get you a PN. Otherwise just get a hold of Blount. He knew what I needed.
                          • e30rapidic
                            • 2167
                            to clarify - I'm talking about the rubber plugs, not the valve cover gasket. but to each there own.
                            • CabrioPunk
                              • 1451
                              Even clearer, I know. The bungs.
