What's your whp?
  • M20power93
    • Feb 2011
    • 84
    What's your whp?
    I'm just curious to know what everybody's whp is whether it's factory or with mods or whatever, tq would be cool too. be detailed if you can.
  • 619E30
    • 1753
    I should be dyno-ing my car within the next couple weeks, I will post when I get results.
    Originally posted by audiquattrot
    bimmers b4 b*tches....remember that.
    1990 Alpinweiss 325i - secret 500whp build
    2000 Audi S4 B5 Laser Red
    1990 Nissan 240sx - Drift Missile
    2006 CBR600RR
    • mr.vang
      • 4371
      stock m42 236,xxx 100whp..
      • DmcL
        • Apr 2009
        • 260
        133whp most recently but theres something up with the engine physically because i was on a wee tuning session on the dyno and nothing i tried would make any real difference to peak numbers. i tried more/less advance and also more/less fuel but end results were always within a window of maybe 3hp of my 133whp run. bit like im hitting an invisible wall at 133whp.
        Currently E30-less
        - EthosMotorsports.com
        • reelizmpro
          • 9558
          88 M3 2.3 liter 284/276 cams, CF intake, street tuned - 200rwhp on dynojet. Hoping to get 220rwhp after the rebuild.
          91 M Technic 2.5 liter, turbocharged - 265rwhp @ 12lbs of boost tuned on Dynapak.
          88 M3 - LACHSSILBER
          89 M3 - ALPINEWEISS II
          • ForcedFirebird
            • Feb 2007
            • 8300
            134whp/145wtq m20b27 with 885 top end and Motronic 1.3 upgrade, stock eta exhaust, stock airbox, stock chip, stock inj etc etc.
            john@m20guru.com
            Links:
            • Holland
              • Nov 2008
              • 7212
              93.7 whp of solid M10b18 fury.
              Originally posted by DEV0 E30
              • stoker1010
                • 10
                121rwhp.
                323i L-jet
                Shick 284/272 cam
                headers - 2.5 exhaust
                • reelizmpro
                  • 9558
                  Originally posted by stoker1010
                  121rwhp.
                  323i L-jet
                  Shick 284/272 cam
                  That's good power! Any plans for 2.7 conversion?
                  88 M3 - LACHSSILBER
                    Numbers don't mean a lot by themselves as different brands on dynomometers produce diffeing results. Comparison the other cars on the smae dyno is much more meaningful. That said, my Spec E30 made 162hp/155tq on a DynoJet on a 100F day. The numbers would have been a bit higher on a cooler day. As an FYI, a Spec E30 is required by the rules to have bone stock engine and management system.
                    • ForcedFirebird
                      • Feb 2007
                      • 8300
                      Originally posted by jlevie
                      Numbers don't mean a lot by themselves as different brands on dynomometers produce diffeing results. Comparison the other cars on the smae dyno is much more meaningful. That said, my Spec E30 made 162hp/t115tq on a DynoJet on a 100F day. The numbers would have been a bit higher on a cooler day. As an FYI, a Spec E30 is required by the rules to have bone stock engine and management system.
                      115tq?
                      john@m20guru.com
                      Links:
                      • stoker1010
                        • 10
                        Probably leave it as is. It is a bit of a classic car when it is its original trim.
                        • e30trooper
                          • 11576
                          m20b27 (stock eta) 320,000 miles
                          had a few issues at the time
                          Made 88Hp to the wheels at 4953 rpms ( stock ship )
                          Made 118 ft lbs of tq at 1800 rpms
                          This was done on a Mainline Dynolog
                          3rd gear pull till rev limiter
                          Only mod was a short ram intake and 87 oct. gas
                          few intake leaks , not sure what happened at 3700-4400 rpms
                          Funny how ppl wasy the eta loses power at 4300, i had peak at 4900
                          dam how i miss that car!
                            Originally posted by ForcedFirebird
                            115tq?
                            Typo, should have been 155tq
                            • wakdog
                              • 223
                              My 323i made 123whp at 5200rpm, It has slightly higher comp pistons from an e21 m20 (no idea of what it was) heavily ported AMC head and a reground cam of which i know not alot about.
                              Car was running L-jet but last track day did a bearing so out with the 2.3 and in with the 2.7 bottom end i had built last year, and at the same time Ill be converting to megasquirt/running 325i intake mani and m30 TB as well as a proper exhaust so it should be interesting to see what it makes then...
                              90 318i M62B44 OBD1
                              02 530i Touring (Airlift 3P)
