Valve spring compressor
  • F34R
    sLaughter
    • 12376
    I searched and could not find any info on what one works best.
    I am wondering what one to get to do the head.
    I found this one and it seems like it would do the job well.
    VALVE SPRING COMPRESSOR BRIGGS & STRATTON 19063
    http://cgi.ebay.com/VALVE-SPRING-COM...#ht_1367wt_907
    Or the C-clamp style? It seems to me it would get in the way...
    Instagram: @BWeissLeather
    Current cars:
    ~ '87 325 M30B35 swap
    ~ '87 535
    ~ 01 540 Msport 6spd
    ~ '06 X5 4.8is
    The only compressor I've had success with is the C-clamp style. I got mine from Sears.
    • F34R
      sLaughter
      • 12376
      I am wondering how a C style will get past the #21 part when clamping.
      http://realoem.com/bmw/showparts.do?...66&hg=11&fg=25
      Current cars:
      ~ '87 535
      ~ '06 X5 4.8is
      • riceh8r
        • Dec 2010
        • 133
        you need a forked angle compressor. you will have to have plenty of room to work the top and get the retainers out
        i bought one that wouldn't work, my dad had this one just laying in his garage...thanks dad !!!
          • 34839
          C type works just fine
            The side of the compressor that depresses the spring is split to allow the keepers to be removed.
              • 34839
              seriously, sears, $25 (maybe $5 more, it's been about 6 years), can't go wrong. you can order online and pick it up at the store.
              • F34R
                sLaughter
                • 12376
                Ah
                I am getting the C style, I think I might even have one laying around at the shop...
                Current cars:
                ~ '87 535
                ~ '06 X5 4.8is
                • StereoInstaller1
                  GAS
                  • 22679
                  whatever you do, don't loan it out EVER.
                  Closing SOON!
                  Thanks for 10 years of fun!
                  • carfantiti
                    • 790
                    okay best way to get off is a socket and a hammer!I rebuilt my head was so easy tap tap cabling.I bought a auto zone one and cut it up to put back on work!
                    • browntown
                      • Jun 2004
                      • 3524
                      I too tried several styles, and finally bought the sears c-clamp and it worked like a charm. Also, you don't need them but the best tool purchase I've made recently is snap on valve seal pliers. Pulled all 12 ancient/brittle/stuck sob's in 2 minutes:
                      Pliers, Valve Stem Seal
                      Stock#: YA8230
                      • Cabriolet
                        • 9620
                        Stock#: YA8230
                        after rebuilding 3 heads myself, i can attest to how easy this tool makes the job. and you dont have to worry about ruining the seals.
                        and i have used a c-clamp to put the valves back in, but it does take two people to make it easy.
                        Much wow
                        I hate 4 doors
                        • moapys
                          • Jan 2014
                          • 9
                          OHC valve-spring compressor from Sears
                          Part number 947627 (large "c" type; two forks supplied); worked perfectly on E30 this afternoon.
                          ...'tensioner sheared...twelve - count 'em, ALL DOZEN valves bent. At least tool made quick work of things, and no chasing keeper/collets.
                          • TimeMachinE30
                            • Jun 2014
                            • 3749
                            The right tool is always such a pleasure..
                            ACS S3 Build / Dinan 5 E34
                            • jeffnhiscars
                              • Jun 2011
                              • 6011
                              The collets (valve spring retainers) love to jump out just as you are releasing the compressor so I've always used a small dab of grease to hold them in place. Best practice #2 is to give the top retainer a sharp tap (no metal on metal pls) to seat the collets. They can bind and throw off your valve adjustment or worse, one pops off when you start er up and your valve drops.
                              Just my 2c
                              Alice the Time Capsule
