Valve spring compressor
  • McGyver
    • 4634
    Bumping this.
    I need to get a valve spring compressor. I plan on using it once or twice a year, so I don't need something super nice. On the other hand, I don't want something that is impossible to use or has a high risk of screwing up my cylinder head.
    There seems to be two may types I'm looking at, a screw compressor and a lever compressor. I'd appreciate any feadback on which is "better" and why. Also, how much am I overthinking this?
    The screw type seems like it would be simple to slowly apply pressure, but I'm concerned about the "screw side" rotating on either the spring retainer or the valve's combustion face:
    The lever type would avoid the screwing action, but I'm concerned actuating the lever may take a lot of force and tool has the potential to move around when the lever is locked/unlocked:
    • Vincenze
      • Apr 2019
      • 1030
      I used the second type.
      The lever actually makes installation and removal easier.
      The finicky part is screwing in the collet as the spring wants to push it away.
      I think the first type is made of a pipe, which may bend.
      • moatilliatta
        • 6151
        / Thread
        I cut this in half and do a cylinder at a time.
        @Zakspeed_US
        • McGyver
          • 4634
          Originally posted by moatilliatta
          / Thread
          That would be great if I was building a DOHC engine, but I'm working on an m20
          • moatilliatta
            • 6151
            Ah. my fault... I've had luck with the basic ones from autozone on the M20. Threaded push with 2 stamped steel clampers.
            @Zakspeed_US
            • Vincenze
              • Apr 2019
              • 1030
              Maybe, I don't understand how to use the tool correctly. But I locked the lever and then slowly screwed in the tool from the bottom until a spring was compressed. So, essentially I used it like the first tool.
              • Northern
                I like cupcakes & sh!tboxes
                • 5247
                I used the lever one, essentially adjusting it so that when the lever is compressed, it compresses the spring/retainer just enough to get at the collets.
                The range of motion is way more than you need to compress the valve, but it gives you lots of clearance to move the tool around.
                Once it's set, you don't need to use the threaded part at all.
                The mechanical advantage over the spring isn't bad but if you're taking apart a head that hasn't been apart in 20 years, the collets stick to the valve retainer and take some force to "pop" apart.
                Originally posted by priapism
                Originally posted by shameson
                • ForcedFirebird
                  • Feb 2007
                  • 8300
                  I have done literally thousands of m20 valve springs. I use a simple 12" c-clamp with a socket that has been notched and welded to the end.
                  Here's one that still floats around the shop made a long time ago, but prefer threads over the levers....
                  https://i448.photobucket.com/albums/.../m54b30007.jpg
                  john@m20guru.com
                  Links:
                  • ForcedFirebird
                    • Feb 2007
                    • 8300
                    / Thread
                    A quality stud remover is what decreased my head rebuilding times for 24v. Had three to do in a row one week, and started double-nutting them out. Decided to call the tool truck and see what he could do. Showed up in an hour with 6, 7, and 8mm stud removers. Took about 10min to pull all the studs from all three (intake, exhaust and cam tray). :)
                    Now if there was just less valves/seats to cut, it would really cut down rebuild time lol.
                    john@m20guru.com
                    Links:
                    • Tinkerer007
                      • Mar 2013
                      • 252
                      What kind of stud remover did you get?
                      A collet type like this:
                      https://www.ebay.com/i/284145810961?...saAq1IEALw_wcB
                      • ForcedFirebird
                        • Feb 2007
                        • 8300
                        Something like that..
                        john@m20guru.com
                        Links:
                        • McGyver
                          • 4634
                          Does it actually do a good job of the install?
                          • Tinkerer007
                            • Mar 2013
                            • 252
                            I think that stud remover functions on a locking cam action.
                            The collet style squeezes the stud with a threaded insert. It is pretty cumbersome and time consuming to use the collet type, but it does hold pretty tight. I think it holds tighter than my cheap locking cam type.
