E head i internals
  • Bmwmotorm52
    • 145
    E head i internals
    i have a crack head (m20b25) ill like to know can i use E head (m20b27) and my is internals on my (m20b25) block? Im trying to find out if i could swap the head.
    sigpic:):)
    • 37832
    There may be a way to make it work but no, you'd be much better off getting another i head.
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • digger
      • Nov 2005
      • 6148
      no pistons likely smah into the head
      • Bene
        • Feb 2011
        • 358
        while we're on the subject, if my eta head internals are worn out, could I have it rebuild with i internals? rather than swaping in an i head, to avoid the compression loss?
        *with an eta block.
          The ETA head has smaller intake and exhaust ports and is missing some oil passages. I believe the oil passages can be drilled out, but the mass flow restrictions would cripple an M20B25 engine. The mass flow restrictions would limit the effectiveness of the head when used on an M20B27. I don't know if the valves would clear the pistons.
            • 34839
            no, you can't use a 200 head on a bottom head meant for an 885 head. The pistons will smash into the head.
            nor would you ever want to do this.
            • Bmwmotorm52
              • 145
              thanks, i just pucked up an new head today.
              sigpic:):)
