cant turn motor over by hand! (found out why)
  • MTechnikII
    • Jun 2007
    • 83
    take the valve cobver off and check and see if anything is cought in the mechanisem to prevent it from turning.
    Henry
    • whodwho
      • Jun 2008
      • 1547
      Originally posted by riceh8r
      just because crank timing mark is lined up does not mean #1 is at tdc.
      Unless the front pulley/dampner was installed incorrectly then it does
      My M20 Frankenbuild(s)
      4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
      • Killacortes
        • 1937
        Originally posted by billybobjoseph
        You know if the marks are lined up and you have the belt on you should be able to turn it. What was the original problem that brought you to get a new head? I think I would take off the belt and make sure the intermediate shaft turns. If it does put the belt back on and make sure you didn't have it a tooth off or something. Take the crank around two complete revolutions and make sure when it's back to TDC the timing mark on the cam is aligned with the mark on the head again. If you still can't turn it take the head off and check the cam shaft turns and the crank turns.
        how do i turn the intermediate shaft? im guessing that is on right of the timing cover?
        i dont see why it wouldnt be at tdc when the head was off piston 1 was at the very top and the marks were lined up
        its pretty hard to incorrectly install the dampner cause it has a hole for a pin that can only go in one way
        r3v does not fuck around. First you get banned, then they shoot you
        • gkobez
          • Jan 2011
          • 184
          How long was the head off for? was the car outside with the head off ? I have experienced instances where if you have the head off for a prolonged period of time, slight amounts of rust may form to the pistons, restricting the movement. This would only be a place to start thinking about IF your timing is right and you see no other reason for movement restriction.
          • M-technik-3
            • 18946
            Pull the valve cover soak the head with some oil, close it let it sit for a bit and come back to it with a fresh start. The head did you add any sort of lubricant after the machine work?
            While it's open take a look at the cam lobes you will know if you are close to TDC.
            • billybobjoseph
              • 213
              Once you have the belt off you should be able to turn the intermediate shaft with your hand. Yes its the one directly above the crank. It turns the shaft that drives your oil pump.
              • riceh8r
                • Dec 2010
                • 133
                i had an eccentric that was rolled too far, it made it very hard for the rocker arm on the high point of lobe. might try backing them all off, you need to reset them anyways. good luck.
                • Killacortes
                  • 1937
                  the head was off for quite a while from what PO said. there was no rust on top of the pistons or on the cylinders.
                  the machine shops said they lubricated the cams.
                  thanks ill try turning it tonight.
                  ill try it, the guy who did the head said he adjusted all the valves
                  • Killacortes
                    • 1937
                    feelin pretty dumb right about now. so when i bout the head it came out of a 90 325is and when i talked to the seller of the head he said that his car never burnt any oil or anything but was just really slow. I still couldnt figure out why the head wouldnt turn but when i took it apart again i found out it was a 731 head! lol now i need to find a 885 head. and keepin this one for a 2.7i
                    • Gruelius
                      • Oct 2009
                      • 298
                      LOL
                      least u found it out.. and didnt try cranking it with the starter
                      RIP 84 323i coupe 5spd w/ 14psi
                      89' 318i
                        • 34847
                        wow, that's crazy. at least you got a good 731 head?
                        • billybobjoseph
                          • 213
                          Nice you got it figured out :)
                          • Kershaw
                            • 11822
                            m20b27 swap. lol.
                            at least you didnt crank it and damage something.
                            AWD > RWD
                            • M-technik-3
                              • 18946
                              How did you not notice it was a 885 head? I mean when you bought that would have been the first thing I looked at was the stamps on the head.
                              • e304me
                                • Feb 2006
                                • 1374
                                I was hoping the reason was going to be that you had it in gear
