Help! Crusing @ 60mph 5th gear 4000 revs
  • Bahama325
    • Dec 2010
    • 9
    #31
    i think this may help
    "The speed sensor gear is typically mounted on an eccentric to accomodate
    installing different gear sizes to account for changes in the ring and
    pinion gears. If your car had 3.07:1 gears, and you wanted to change to
    4.10:1 gears, then you would need a new speed sensor gear so your
    speedometer and odometer remained in proper calibration. Since this would
    require speed sensor gears with different tooth counts, then the speed
    sensor gears would necessarily be different sizes, and would need to be
    mounted differently in order to maintian the proper gear mesh."
    • supkev
      • 912
      #32
      my redline is 7k also.
      • LJ851
        • 7919
        #33
        http://newsgroups.derkeiler.com/Arch.../msg00512.html
        The speed sensor in a BMW diff is mounted to be triggered by a chopper wheel on the output of the diff. It doesnt know what the gear ratio is nor does it care. Tire diameter is the only thing that affects its reading.
        Lorin
        The M30 is God's engine.
          • 34847
          #34
          My red line is 7gs, after reviewing the two sensors there is a big difference, i think that is the culprit, i am going to replace, on the stock diff the sensors are uneven and on the 4.10 they are even.
          No. all bmw diffs use a 9 tooth wheel. It doesnt matter what ratio you have, the culprit is you have the wrong coding plug for the instrument cluster.
          • o.d.
            • 101
            #35
            hook up an external tach just to check the rpm's
            • kamotors
              • Nov 2007
              • 7102
              #36
              definitely tach, not even a 4.27 revs that high
              7speedshop.com
              • supkev
                • 912
                #37
                alright I'm gonna buy another tach since my odo and stuff don't work I could use it
                • Zesty Bonanza
                  • Apr 2011
                  • 88
                  #38
                  Originally posted by nando
                  your tach is probably not reading correctly
                  I think the Euro Tach is reading the RPM incorrectly. I test drove an e30 that had a tach in which the RPM wasn't correct because the redline gas cutoff was about 2k higher than the 6.5k rpm. His tach would increase and then get stuck at 7k while the car would still accelerate. his car also read the speed wrong, but it was in MPH instead of KM/h.
                  Then I test drove another guy's e30 and described the issue of the previous car that I test drove and this guy said that the euro tach has the problem of not reading the speed and RPM correctly.
                  I think both of those people are (or were) on this forum.
