Help! Crusing @ 60mph 5th gear 4000 revs
  • slammin.e28
    שמע ישראל
    • 12054
    Originally posted by nando
    I'm telling you - there is no way a 4.10 will do 4000rpm at 60mph. Not unless you're running rubber band tires on 13" wheels.
    This.
    Swap in a good cluster and see what it reads. Easiest diag IMO.
    You say you have a Euro cluster? Maybe it's in metric RPMs? ;)
    JK.
    • pandaboo911
      • 2070
      Your speedo is wrong you're actually doing 85 :P
      • LJ851
        • 7919
        Perhaps you have a close ratio gearbox. How do you engage 1st gear?
        Lorin
        The M30 is God's engine.
        • zxert
          • Jan 2011
          • 444
          He said he drove next to someone who verified the speed.
          Originally posted by StewStewIloveyouyou
          hahahahahahahahahahahahahahahahahah f--- this community its like am making my life with you guys
          And am making my life with you guy too. ;)
          • supkev
            • 912
            ^ I have lined up and done that already, I have also used gps to measure my speed though its not accurate it reads 56-60mph its not that far off
            • supkev
              • 912
              • slammin.e28
                שמע ישראל
                • 12054
                  • 34844
                  the only think I can think of is if you have an eta coding plug in an I tach
                  • supkev
                    • 912
                    I will look into it
                    • Bahama325
                      • Dec 2010
                      • 9
                      Hey guys, i have the same problem, i just recently swapped in a 4.10 in to my 327 stoker with a gearbox from a 325e, my 1st gear redlines at 20mph 2nd is around 45.... no idea how to solve it, i am sure its the diff, i was fine before the swap
                      • nrubenstein
                        • 3148
                        What is your rev limit? A 4.10 is good for a lot more than 20/45 if you have a 6500-7000 rpm limit. Did you forget to change your cluster, or put in one from a 4 cylinder?
                        2002 BMW M3 Alpinweiß/Black
                        1999 323i GTS2 Alpinweiß
                        1995 M3 Dakargelb/Black
                        - S50B32/S6S420G/3.91
                        1990 325is Brilliantrot/Tan
                        1989 M3 Alpinweiß/Black
                        • nrubenstein
                          • 3148
                          Originally posted by supkev
                          A quick check suggests you have a 4-cylinder plug. You could check by seeing if the engine stops revving at the redline on the cluster, or way past. I'll bet you hit "7k" and keep going.
                          • Bahama325
                            • Dec 2010
                            • 9
                            i did change my cluster, but ill try going pass 7, wat i also did was the swap sensors from my stock diff and placed it in the 4.10 so i woulnd have to cut the connectors, that the only thing i can think off that may though it off
                              • 34844
                              What's your redline? you should be able to do 30-35 in 1st and 50-60 in 2nd, depending on tire diameter and the actual limit.
                              • Bahama325
                                • Dec 2010
                                • 9
                                My red line is 7gs, after reviewing the two sensors there is a big difference, i think that is the culprit, i am going to replace, on the stock diff the sensors are uneven and on the 4.10 they are even.
