since ive got the car about 6 months ago, i did BAV autosport wire set and cap, MSD blaster 2 coil, fuel filter, air filter, inner and outer tie rods, lower ball joints w/ control arms/ sway bar links and all new brakes and a new left rear frame rail... but this misfire kills me....
difference in power between m20b27 and the 2.7l stroker motor?
sigpicFellow e30 enthusiast
Dont waste your time hating, aint nobody got time fo dat
1986 bronzit 325es- SOLD
1987 delphin 325i- parts car
1990 scwarz 325is- m50 drift slut
CHECK OUT THE BUILD!
http://www.r3vlimited.com/board/showthread.php?t=229234
anywriteups on testing the MAF?sigpicFellow e30 enthusiast
Just picked up my first e30 and was wondering what is the hp increase on putting an 885 head on a regular eta, since there is a difference in the way the pistons are shaped?Comment
i just bought an m50 insteadsigpicFellow e30 enthusiast
You can do alot with the 2.7 eta bottom end and a 885 head/intake. You will lose some bottom end but nothing you couldn't make up with a chip, cold air intake, 19lb injectors and some 91+ octane fuel. maybe an m30 afm. definitely more torque and more fun. you'll increase the horsepower significantly.sigpicComment
