rs4pro3 MS Kit - HELP
  • Hick
    • Sep 2005
    • 6451
    Does anyone have directions/parts list/schematics that were included in the purchase of a PnP MS kit from Ely? I am looking into buying a kit second hand kit w/o any directions.
    Originally posted by vlad
  • reelizmpro
    • 9476
    Plug it in and Play with it. Just make sure you have a laptop with a serial port or USB to serial and MegaTune or whatever app to program it. Then use a basemap or go get it dynotuned.
    88 M3 - LACHSSILBER/SCHWARZE
    • Hick
      • Sep 2005
      • 6451
      There were directions included in each kit, just trying to hunt them down. I know its plug and play but some wiring DOES need changed. And i have to replace the TPS, add an air temp, and coil packs.
        • 34839
        you could actually run it with a single stock coil to start with. I'd actually reccomend that. just set it to "single coil" instead of "wasted spark".
        as for wiring, you need a wideband, TPS, and IAT. you can use the AFM's IAT. It's probably an MS1 V3.0 board, pretty basic, you can find all the info on the board wiring/schematics at www.msextra.com.
        as far as the wiring between MS and the Motronic harness, I have no idea what he's done there. I've got my own chart that you can try comparing to his with a multimeter to see if you can nail it down closer:
        • Hick
          • Sep 2005
          • 6451
          Yeah, ive got most of that info. The wiring diagram you have charted is probably close, but thats whats holding me back.
            • 34839
            well you can use a multimeter to figure out which pin on the motronic connector is connected to which pin on the DB37. Then we can figure out how it's set up.
            • Hick
              • Sep 2005
              • 6451
              true, just trying to find it before purchasing.
                • 34839
                Ah, yeah that makes it a bit more difficult.
                • matt0300
                  • 549
                  U have to run that vac line, just plug and play and run that line and ur set
