stroker, no fuel
  • mkcman17
    • Jul 2010
    • 8240
    stroker, no fuel
    finished up the swap today, but no fuel is being pumped. swapped in a new pump and still nothing. motor cranks and there is spark, but disconnected the hose from the fpr and before the filter while cranking and found nothing. need this car running. ideas?
    1989 LN106 Hilux / 3.0TD SFA
    1974 2002tii / stock
    2002 IS300 / 5spd LSD
  • reelizmpro
    • 9559
    i Injectors
    3.0 bar fpr
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • mkcman17
      • Jul 2010
      • 8240
      injectors and fpr are being brought over from the 'i'
      • ForcedFirebird
        • Feb 2007
        • 8300
        If you are just swapping the block, then all else stays the same. It's only when you start with an eta car that things have to change.
        john@m20guru.com
        Links:
        • mkcman17
          • Jul 2010
          • 8240
          bump, changed op
          • Myster-E
            Performance
            • 552
            Did you try swapping the cps and impulse wire like I said?
            1988 E30 335i - 1987 E30 327i - 1987 E30 327iS Pickup - 1973 2002 Project
            Visit www.BimmerHeads.com for all of your 12 valve needs!
            • ForcedFirebird
              • Feb 2007
              • 8300
              If the cps and cylinder indentifier reluctors were reversed there would be no spark either.
              Swap the fuel pump and o2 relays, it will start without the o2 heater.
              john@m20guru.com
              Links:
              • mkcman17
                • Jul 2010
                • 8240
                maybe it was unrelated, but we gave up and tried to hook an external battery to the pump, which sparked and started the pump. after that, the pump ran on the tank plug. maybe it just needed a good kick?
                • ForcedFirebird
                  • Feb 2007
                  • 8300
                  If it sat for a bit, maybe, gas will varnish over time and can freeze pumps and injectors...
                  Have reversed the polarity on them in the past to get them moving.
                  Fill with fresh gas and change your filter.
                  How's she running?
                  john@m20guru.com
                  Links:
