2.8 Stroker Injectors
    • 37828
    I can fucking guarantee you that 17lb injectors are not big enough for a 2.8L with head work. More air flow + more compression + 2.8L = needs more fuel.
    Just because it "runs fine" on 17lb injectors doesn't mean it isn't lean as fuck. I do love M50 injectors for stock and mild M20 engines though!
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
      • 34835
      they are if you run them at 3.5-4.0 bar instead of 3 bar. :)
      • delatlanta1281
        Dart Master
        • Mar 2006
        • 10317
        Ok, so I can run 19lb injectors with a regular fpr in my stroker and it will be ok?
        Yours truly,
        Rich
        you kids get off my lawn.....
        • acolella76
          • 2950
          whoa easy there big guy, no reason to get so upset
          yes there is no need for an AFPR. You good.
          -Alex
            • 34835
            yes
              • 37828
              There IS reason to get upset. I can promise you I have had the MOST real life experience with these cars and their engines out of anyone on this forum. I have worked on, pulled, installed, and driven E30's with pretty much every M20 combo under the sun.
              I like my R3V information like I like my hookers, truthful.
              Grover Beach, CA
              www.BimmerHeads.com
                • 34835
                going by injector DC, 21# would be perfect for my motor, but I'm figuring most people don't put much work into them and are just slapping parts together and hoping it starts.
                • IronmanE30
                  • Sep 2009
                  • 2121
                  LOL, so you like truthful hookers... "Oh Matty you are the best I ever had." Just learning about the stroker build, this is good information.
                  Cheers,
                  Jim
                  • E30_fiend
                    • Apr 2006
                    • 7348
                    ok. What say you to 19lb injectors at 3.5bar?
                      • 34835
                      there are many calculators for figuring out injector flow after changing the base pressure. you just need to know what base pressure they were set to originally.
                      • E30_fiend
                        • Apr 2006
                        • 7348
                        wanna shoot me in the direction of one of these calculators? Im just interested to hear your thoughts on 19lb injectors with a higher pressure. Better fuel mileage and better power? worse fuel mileage and better power? worse mileage and worse power?
                        Taylor
                          • 34835
                          it won't change power. it will just decrease the pulse width (needs to be tuned for it of course). The higher pressure atomizes better. It also affects response time. of course there's a limit to how much pressure you can put through them..
                          www.google.com :p
                          • E30_fiend
                            • Apr 2006
                            • 7348
                            this guy^^^
                            Im wondering if a 3.5bar fpr would be better for my 19lbers or if it would just be a waste of money.
                              • 34835
                              it might be a small increase in efficiency, but unless you already have the ability to tune it yourself it's going to be a lot of work for 7.4psi of fuel pressure..
                              • E30_fiend
                                • Apr 2006
                                • 7348
                                that makes sense.
