2.8 Stroker Injectors
  • jules325i
    • Jul 2011
    • 353
    Will i need bigger injectors or can i just get away with an adjustable fuel pressure regulator (and crank it up).
    329i
  • Robotin
    • Jun 2011
    • 4471
    SETA stroker?? if so.... makes me sad... if your running the stock fuel pump... the m50 17lb injectors will make your fuel pump breathe better. but with an adjustable regulator. if u "crank it up" u should probably put something a little bigger in.
    1989 325i SETA stroker [delphin] R3V'd 8/31/2011
    1989 325ix [zinnoberrot] $OLD
    1970 2002 [Nevada]
    Originally posted by Herr Faust Schinken
    guy must have slid into something that doesn't look like a car vs car hit
    Originally posted by ak-
    Must of slid into Rob
      • 37832
      A 2.8 stroker is not the same as a Super Eta 2.7i engine.
      OP for the 2.8 I'd recommend 19lb injectors and adjustable FPR.
      Classic BMW Specialists
      Grover Beach, CA
      www.BimmerHeads.com
        • 37832
        Also, stock fuel pumps are just fine. My turbo E30 has a stock fuel pump. :)
        Grover Beach, CA
        www.BimmerHeads.com
        • acolella76
          • 2950
          Idk if an AFPR is necessary, but 19lb/hr injectors are what I would use.
          -Alex
            • 34839
            leave the FPR alone. just change the injectors and get a tune for it.
            • E30_fiend
              • Apr 2006
              • 7348
              No need for the afpr. The stock fuel pressure will feed the 19lb injectors just fine. I dont care how much bigger your bottom end is. You wont need more fuel pressure. Its not FI so you shouldn't need THAT much more fuel.
              Taylor
              • jules325i
                • Jul 2011
                • 353
                Sweet I'll go with bigger injectors.
                Any sugestions.. IE?
                329i
                  • 34839
                  M50 injectors are plenty big enough for any M20
                  • E30_fiend
                    • Apr 2006
                    • 7348
                    Find some Bosch design II's out of newer Ford v8
                    • F34R
                      sLaughter
                      • 12376
                      1+ same thing I am running in my brother's 2.8 stroker.
                      Instagram: @BWeissLeather
                      Current cars:
                      ~ '87 325 M30B35 swap
                      ~ '87 535
                      ~ 01 540 Msport 6spd
                      ~ '06 X5 4.8is
                      • Robotin
                        • Jun 2011
                        • 4471
                        figured he was rounding up... sorry yall... my bad... what did u do to get the full 2.8?
                        1970 2002 [Nevada]
                        • F34R
                          sLaughter
                          • 12376
                          m52 crankshaft, eta rods and b25 pistons.
                          Current cars:
                          ~ '87 535
                          ~ '06 X5 4.8is
                          • digger
                            • Nov 2005
                            • 6129
                            any M20? noway
                              • 34839
                              Okay, 99% of the builds here, yours not included. ;)
