I want more torque for my ETA
  • 2mAn
    SeƱior Mod
    • 21049
    Im enjoying my 86 ES a lot and want to do something different from the typical "swap everything from an I" build. I don't want more horsepower, I want more torque. I want it to stay NA, so no supercharging for me. So far, I just have a chip and am sourcing some long tube headers and exhaust, but beyond that I'm not sure where to go for more torque. Is there anything else out there that BMW hasn't already done? I will change the final drive, but only bumping it slightly, dont expect me to run a 3.73
    thoughts?
    Simon
    Current Cars:
    -1966 Blue Boat
    -1969 Red VW
    -1986 White BMW
    -2006 Green Thing
    Make R3V Great Again -2020
  • Cronopoulos
    • Jul 2011
    • 2187
    A 3.73 will help it out a lot. It's really not all that bad cruising at 75+
    Project log -- DIRTY 30
    2.7i * Megasquirt tuned * E85 powered
    • Blackangusinc
      • Jul 2010
      • 244
      This
      971-295-7077
      91' 318i
      • digger
        • Nov 2005
        • 6199
        you can't get more torque without getting more hp at the same rpm. At what rpm do you want more torque and hp?
        a bigger crank will do the job as it gives you more CC and higher CR if you get a piston that geometrically works properly.
        get a adjustable cam gear and play around to see what works. A proper tune usually helps out aswell.
        • Wanganstyle
          • 2828
          change the final drive to a 3.15 or 3.23, my eta is currently running a 3.15 and its nice for 2nd gear starts on downhills lol
          increase the compression & increase the displacement, install 885 head with ETA cam if you like, that should flow better
