284/272 Cam
  • jules325i
    • Jul 2011
    • 353
    284/272 Cam
    I'm about to order it, my engine will be running 2.8l with 10:5.1 compression how will my drivability be.
    i was considering the 272 degree but some say that the 272 is pretty crap.
    329i
  • stoker1010
    • 10
    My 323i has a 284/272. My exhaust headers may be little large for engine size and compression a bit low, so it loses a little torque below 3000 rpm. Over 3500 rpm it kicks in pretty good.
    • peteb3
      • Nov 2009
      • 163
      I had a 284/272 in a stock compression M20 with minor head work and supersprint headers, running a Turner chip and stock AFM
      It rocked above 4000 rpm, idle was a bit lumpy but still good
      For 10.5 to 1 the cam shoudl be awesome, hopefully you have good headers and an exhaust as well
        • 34844
        it's definitely a good match to your CR/displacement
        idle should be fine, just bump the idle speed up to ~800rpm and fatten up the idle AFR a hair (~14.5:1 or so).
        • SkiFree
          • Jun 2011
          • 2766
          Some say the world was going to end a couple times this last year but that doesn't mean they were right.
          For your setup however, the 284/272 sounds like a good match.
          ADAMS Autosport
          • Wanganstyle
            • 2828
            I'm driving this now, is pretty well matched. (10.5:1, 272)
              • 34844
              a 272 isn't really crap, it's just that all cams cost about the same and the idle/driveability with the 284/272 is still comparable, so why waste time/money on the 272?
              • digger
                • Nov 2005
                • 6194
                i would look at dbilas cams they have more options in the 270 to 280 range (Varying LSA and lifts etc)
