m20b25 engine build idea helpppp
  • BrandonG
    • 232
    so i am planning on running a M52B25 crank in a m20 b25 with M52B25 eagle rods and m20b25 wiesco 9:1 pistons with a m20b20 cam all so i can boost it later down road does this set up sound like something someone has done or possible ? reason for m20b20 cam is i heard it is same as a 262 any tips or links to similar builds would be awsome
    DO WORK
    • 34839
    use the B25 cam, at least.
    • Kershaw
      • 11822
      get a 304 if you're going to be building the engine anyway.
      AWD > RWD
      • BrandonG
        • 232
        yea i might use the stock cam and all m50 rods and stock pistons and a headspacer and run some boost through it with a war chip im olny shooting for 260whp
        DO WORK
          • 37828
          You want to build a stroker and boost it but you're going to use a stock cam?
          Classic BMW Specialists
          Grover Beach, CA
          www.BimmerHeads.com
            • 34839
            an M52B25 crank doesn't make a stroker, either. it's still a 75mm stroke. why would you use a head spacer? the stock CR of an M20B25 is already perfect for boost, which is basically what you'd have after all that.
            • BrandonG
              • 232
              not making a stroker lol just wanna make it stronger b4 boost and wats the cr of a m20b25 after all this im new to bmw engines
              DO WORK
                • 34839
                a head spacer would probably just make things worse. you'd lose the quench area of the stock combustion chamber.
                I don't think there's any point in using an M52B25 crank. the M20 crank is plenty strong enough. the only advantage to the newer rods is they weigh less.
                if you're going to bother with custom pistons, you may as well increase the stroke with an M52B28 crank, or even better, an S52B23/M54B30 crank. The cost difference is going to be maybe $100.
                • BrandonG
                  • 232
                  hmmm so m20b25 pistons , m52b25 rods, m52b28 crank ???? and a gt30 sound legit
                  DO WORK
                    • 34839
                    that won't work either.
                    you need to do more research. :)
