best spark plugs for an m20 what do you use?
  • cabriodster87
    • Jan 2011
    • 1042
    Bosch.
    Reich und Roll!
    • Mullet Bullet
      • May 2011
      • 904
      Originally posted by nando
      funny, BMW seems to think NGK works good enough to be the factory plug for the S54. But I guess you're smarter than their engineers..
      reading comprehension>you we are talking about M20's, not S54's. and again like i stated above, i run what the factory puts in.
      Originally posted by nwvb bmw
      That guy is going to lock you in his basement and make you ware a little pirate costume.
        • 34839
        what? you said NGKs were for asian cars. I think that's pretty clear (and stupid).
          • 37828
          I run NGK plugs in the turbo M20. Can't remember the p/n though.
          Classic BMW Specialists
          Grover Beach, CA
          www.BimmerHeads.com
          • HR2L
            • 724
            Originally posted by MR 325
            I run the OEM spec Bosch Super in any N/A M20.
            This. ;-)
            • illest318i
              • 1472
              I know this is unrelated but what about an M10, what do you guys recommend?
              IG: @_j.wn
              • HR2L
                • 724
                Bosch WR9DS or NGK BPR5ES for stock m10. Gap to .034" and call it good. ;)
                • Mullet Bullet
                  • May 2011
                  • 904
                  i guess you are thinking too hard about what i said. i could have worded it differently but that is what i meant.
                  • Northern
                    • 5129
                    replaced my bosch supers with cheapo copper ngks with .033 gap, since I couldn't find anywhere that stocks bosch supers. old plugs were old and fouled, ngk plugs work great.
                    Originally posted by priapism
                    Originally posted by shameson
                    • abit
                      • Jul 2011
                      • 416
                      maybe someone can suggest plugs for tuned m20b30 with cr 11.4 ?
                      I think that stock ngk's won't be the best choice anymore
                      mostly street, sometimes track use.
                      http://instagram.com/mundieriss
                      my 88' m20b30 HERE!
                      • digger
                        • Nov 2005
                        • 5983
                        bpr6es work well enough as they are a step colder , otherwise for another step colder again bpr7es if they run too hot assuming you have stock plug leads etc that need the screw off tips
                        • estoguy
                          • May 2013
                          • 1087
                          NGK ZGR5A for my Eta. No issues ever.
                          Estoguy
                          • abit
                            • Jul 2011
                            • 416
                            OK, thanks.
                            should I re gap them or standard 0.8 would be fine ?
                            I'm using COP setup with m54 coils
                            my 88' m20b30 HERE!
                            • BaltimoreBimmer
                              • Apr 2016
                              • 307
                              So I don't see this mentioned on forums, but do we have to "tip" or properly space the spark plugs before putting them in? I wasn't even aware this was a thing, or maybe thought it was more prevalent on significantly older engines. Brought it up to my old man and he was like, well of course you have to space the tips properly....
                              Or is the point that if you get particular plugs made for this engine, you don't have to. Because I didn't on my e30 and didn't on my e46 either.
                              • estoguy
                                • May 2013
                                • 1087
                                The ZGR5As should be fine out of the box. I forget what they are gapped to, but it's the upper end of the range for them. A gap at the wider end helps stabilize the idle. I've never gapped mine, but always check them before installation.
                                Estoguy
