simple hidden m20 perfomance?
  • acolella76
    • 2950
    #31
    Someone told me that the M20 came with a turbo hidden somewhere in the engine bay, but I looked for it and I can't find it. Anyone know where it is????
    Also, I advanced the timing by 2 teeth on the cam wheel and now it makes this PANG PANG PANG PANG PANG noise and runs like shit????????????
    can anyone help????????
    -Alex
    • paperplane94
      • Jul 2011
      • 420
      #32
      Do a burnout:D.
      • timninja
        • Feb 2011
        • 302
        #33
        Yeah there is a switch that says NOZ on your steering wheel to turn it on and your Turbo is a mach 1 it's under your seat,..
        • Jean
          • 18228
          #34
          Chip tuning an M20 seems like a crapshoot w/o going turbo imho.. Same as M10 and M30. These are SOHC and don't breath for crap.
          Originally posted by Exodus_2pt0
          Looking forward to this.
          Yep!
          • timninja
            • Feb 2011
            • 302
            #35
            Yeah its imo to but I should've rephrased my title I ment easy,I don't know much about the m20 yet so why not bite the bullet and ask?
            • CptnVortex
              • 46
              #36
              Sooo.... over the weekend when I rebuilt my head, I gapped the valves at .010, in the cold (about 5c). Anyway, after I installed the head and got it running, I just went and checked the gapping as I assumed after running a bit the valves/springs would probably seat in a little more....and I was right. I couldnt even get the 0.008 feeler in ANY of the gaps!(cold again, this time almost -5c) Good thing I saw this thread earlier and decided to check!
              • mikeb23ft
                • 390
                #37
                Seems like dropping a grand on the full Miller setup is the way to go if you got the cash. This is probably what I will eventually do. I like the flexibility and I never plan on going turbo or doing an engineswap so it's worth it. 25/25 gains for Hp and torque isn't bad for 1k.
                • devon.818
                  • Feb 2011
                  • 2937
                  #38
                  that is fucking retared.
                  • mikeb23ft
                    • 390
                    #39
                    Would you be so kind as to elaborate somewhat?
                    • mikeb23ft
                      • 390
                      #40
                      Guess I'm just inexplicably retarded then.
                      • Killacortes
                        • 1937
                        #41
                        1k for 25hp and 25tq is way too much man. 24v swaps could be had for that much if you do the work yourself. A chip can give you those gains for a fraction of the price
                        r3v does not fuck around. First you get banned, then they shoot you
                        • devon.818
                          • Feb 2011
                          • 2937
                          #42
                          because you could turbo it for less and be reliable, and miller is over priced fucking asshatery
                          • mikeb23ft
                            • 390
                            #43
                            I specifically said I never wanted to turbo it or do a swap but thanks for the input. I am aware that I could make more power for less. If that was what I wanted I would have a camaro, a nitrous bottle, or both. Next time reserve your comments about retardation for situations to which they apply.
                            • smooth
                              • Apr 2005
                              • 1940
                              #44
                              The point is that you can chip your car for a whole lot less and get similar gains. The Miller/MAF setup might be worth something if you were going to do the tuning yourself. But if you're not going to then just get a pre-baked TMS chip and call it done for 1/3 the price.
                              Das ist nicht nur nicht richtig, es ist nicht einmal falsch!
                              • devon.818
                                • Feb 2011
                                • 2937
                                #45
                                ok so no turbo.
                                you can refresh your motor; resurface, new rings, bearings, ect for under 800! then take that last few hundred get a good chip and a 4.10lsd and call it a day...
                                kamotors intake and remove the cat-converter from your exhaust system and done.
                                a mild cam too
                                i had a miller MAF and was not impressed! i was more happy about how it tidied up my engine bay than the "performance" i "gained"
