M20 seized?
  • bastianshaw
    • Jan 2007
    • 2210
    M20 seized?
    Looking at a car on cl. Dude says the motor is frozen but has always run oil and adjusted the valves so he doesn't sound like a complete noob. Can the mechanical oil pump fail? I've never heard of it. What else can cause a motor to seize? I think it's just the starter might be frozen to the flywheel as the guy said you can hear the starter "click"
  • TimKninja
    • 2131
    Take a 22 mm wrench to the crank bolt.
    Starter solonoid could be bad too.
    1985 325e M50TU(Sold)
    1991 318is Slicktop (Sold)
    1990 325is Brilliantrot S50/5 Lug Swapped.
    1992 525i Manual shitbox Winter Beater
    • bastianshaw
      • Jan 2007
      • 2210
      Yea I know but getting to that bolt is like an hr long process and then if it turns the guy might not want to sell it :-/
      • Rigmaster
        • 3464
        WTF? Getting to that bolt is like a 2 second process.
        Just stick your head under the hood with a wrench and see if it turns, he doesn't need to know exactly what you're doing.
        EDIT: the starter click could be a bad starter, or bad wiring, or almost dead battery. To make an informed decision, you just need to know if the engine is locked up or not- that should help determine how much the car is worth to you.
        • TurboJake
          • 3780
          You know what can cause a motor to seize?
          A leaky headgasket filling the cylinder with coolant while it's sitting.. Pull the spark plugs and then try to crank with the starter, wrench, or ratchet.
          Make sure you don't do it inside their garage though. They tend to get angry.
          Leave Me Transaction Feedback
          • bastianshaw
            • Jan 2007
            • 2210
            Thanks guys I could care less about the head gasket being bad. If it is then all the important maintenance gets done right off the bat and keeps my lazy white ass from procrastinating
            I could have sworn the crank bolt was a pita to get to...
            • bernzpeed
              • 3917
              crank bolt is not that bad to get to. get 22 wrench, turn the engine.
              89 E30 S52
              Transaction Feedback.
              • bastianshaw
                • Jan 2007
                • 2210
                Lol just saw this after I called you
                • bastianshaw
                  • Jan 2007
                  • 2210
                  can the oil pump fail?
                    • 37833
                    Of course it can fail.
                    Could also have a broken timing belt...
                    Grover Beach, California
                    BimmerHeads.com
                    • bastianshaw
                      • Jan 2007
                      • 2210
                      common?
                      • Cletonius
                        • 2809
                        common?
                        Totally unheard of.
                        - Josh
                        1990 325is
                        Need a shift boot?
                        Looking to buy shift boot frames, PM if you have one to sell
                        Here's what happens when you let the internet pick your license plate
                        • BergerNJ
                          • Oct 2009
                          • 349
                          Originally posted by Cletonius
                          Totally unheard of.
                          lol stop.
                          yes it could be broken but it would try and start wouldn't it?
                          • paperplane94
                            • Jul 2011
                            • 420
                            I vote timing belt...
                            Piston><valve=no bueno
                            when you try starting it, remove the oil filler cap and look for any cam movement.
                            If you want to turn it over more easily, pull out the park plugs.
                            • bernzpeed
                              • 3917
                              Broken timing belt = bent valves or damage to pistons.
                              Sent from my HERO200 using Tapatalk
                              89 E30 S52
