m20 running on a stand
  • nomansland92
    • 1657
    I'm sure this has been done before but i think it would be a cool little project and it would give me something to do with my spare motor.
    I picked up a spare ix motor a year ago and it had a bent valve that i have replaced. I'd like to fire it up but I'm not planning on put it in the car for at least another year or more. My motor still runs strong it just has a little bit of piston knock when cold :-(
    So i was think of building a stand and getting all the accessories and extras that it would need to let it fire. I have a lot of parts already because i kept everything i replaced om my car and i have many things haha.
    So far i have
    complete long block
    afm
    injectors
    full engine wiring harness
    dme
    cap, rotor, coil, and wires
    So i've been thing on what i still need witch i know i will these
    intake manifold
    fuel rail with regulator
    any fuel pump that will make adequate rate/psi
    throttle body
    intake boot
    crank and cam gear
    timing belt and tensioner
    Starter
    fly wheel
    ( not decided if i want to set up a cooling system. I would then need the w/p and altanotor to make the belt work unless i can find a shorter one that would only go around the crank and w/p)
    That's everything i can think of but I'm sure I'm missing a few thing
    If you can think of anything else i need please let me know.
    If you have any ideas or tips please fill me in if you wouldn't mind :)
    IX being restored here
    Ix turbo build here
  • nomansland92
    • 1657
    few other things
    oil pressure sender
    oil pump
    idle control regulator
    Ix turbo build here
    • TobyB
      • 5288
      I thought about it for 5 minutes once, then just went out and bought another car
      to put the engine in question into. It was cheaper, faster andeasier and then I had a way of load
      testing the thing when I was done...
      I'm actually serious...
      t
