12v Timing Chain: If you had the Option would you?
  • SpecM
    • Oct 2005
    • 4531
    Originally posted by stamar
    Honda was one of the last big companys to stick with belts. still belt driven into the early 00s. Other then that most cars are chains again nowadays.
    Later than that... my 05 Odyssey has a belt, and I just changed the TB/wp on my friend's 08 Pilot. I'm very sure that the Honda/Acura 3.5/3.7 v6s have belt as late as 2012...
    And Hyundai/Kia used belts until 2010 or so
    Sent from my Vortex using Tapatalk
    1989 cirrisblau-metallic 325i
    • MonkeyMadness
      • 3251
      woa..
      I have to say, I'm quite surprized. All i've ever heard from this forum (R3V) is bitching about the tbelt.
      whining about issues, valve slap on failers, people swaping motors to get away from the issue.
      sure I would love to have a tbelt built like the drive belt on my Harley.
      For the last year I've been working on this issue thinking everybody may want to convert to chain.
      oh well from what i read i was way off base....
      I crack the "Nut".......
      • acolella76
        • 2950
        Like others said if, if it's replaced when it needs to be replaced there's no problem! I looked into a timing chain conversion for my m20 but it wasn't worth it. I just see the timing belt as regular maintenance now...
        -Alex
        • LagunaVert
          • 255
          That is the m20's way of getting the attention it wants!
          TWELVE HAMMERS
          • AndrewBird
            The Mad Scientist
            • 11898
            If you think a timing chain is a maintenance free part then you clearly have never owned an M42. lol
            • MikeDE
              • 1873
              So true, that's why I voted 'Go F yourself'. I would rather change that belt every year than have to worry about sealing a goddamn timing case. I have done numerous t-belt joibs on my 1g/2g DSM's. After those whores, any other belt has to be a cinch.
              All things being equal, a belt is also lighter, cheaper, and cleaner. The chain weighs a ton compared the the belt. The belt and tensioner costs what, like $60 maybe, and cam sprockets/gears don't have to be replaced due to wear, nor does one have to spend the loot on a set of timing case gaskets. Plus no oil is involved, or silicone for case gaskets.
              -03/2005 E46 330D Touring 6spd(204hp/410nM) Sapphire Black/Naturbraun Sport...300k KM & 35mpg(mixed)
              • mikeb23ft
                • 390
                How are you going to lubricate this supposed timing chain conversion?
                • rThor432
                  • Feb 2007
                  • 3907
                  You mean your engine isn't already covered in perpetual grease? If not, removing a rocker plug should do the trick.
                  • stamar
                    • Apr 2011
                    • 1362
                    you are right they still use some belts today. I think the base civic engine is still a belt. but most hondas are chains again.
                    Honda was the big rebel against the trend but the consumers dont like it.
                    hyundai kia is the other company. still some belts but mostly chains now.
                    daewoo was belts, and also some gm cars like the pontiac roadster. but like, all toyotas nissans bmws etc are chains now.
                    • stamar
                      • Apr 2011
                      • 1362
                      there is no question that a chain is the worst design. A self oiling chain is just planned obselescence just flaking off into the oil.
                      I mean its like a bicycle.
                      you just need super belt. Maybe steel belted like a tire? Theyre made by tire companies.
                      • devon.818
                        • Feb 2011
                        • 2937
                        toyota's still use belts :)
                        • strad
                          • Jan 2007
                          • 241
                          My experience so far with timing chain-equipped cars is that the timing chain system is not necessarily trouble free. Sprockets wear out, tensioners wear out, chains stretch, etc. It's not all it's cracked up to be. And all of those parts cost more than a timing belt and its tensioner.
                          The current fleet:
                          1992 325ic: 148k-171k miles
                          1999 Chevrolet Tahoe LT 4WD, 114k-142k miles
                          1984 MasterCraft Stars and Stripes Powerslot (not a car :D) PCM Ford 351W, 904 hours
                          • stamar
                            • Apr 2011
                            • 1362
                            possibly but which ones?
                            the majority of toyotas use chains like from corrolas to camrys to tundras.
                            It is possible the v6 in camrys is a belt.
                            definitely part of the chain movement.
                            some chains do last forever like on toyota trucks. Never a belt in toyota trucks. even lasting forever and never breaking a belt is better. less friction and less metal in the oil.
                            better gas mileage from a belt.
                            • stamar
                              • Apr 2011
                              • 1362
                              actually the honda ridgeline is definitely a belt driven sold in 2012.
                              its the only belt driven full size truck.
                              http://www.gates.com/downloads/downl...older=brochure
                              i stand corrected. The only toyota belt model is the 4.7 liter v8 in tundras.
                                • 34839
                                Belts are more efficient, far cheaper, and if mainained, plenty reliable.
                                /thread ;)
