Mounting shorter injectors.
  • Kvasi
    • Apr 2011
    • 1122
    Going for some more power and just got my new injectors home. Turns out they are about 10mm shorter than the stock ones, and that means fabbing adapters to get the fuelrail mounted.
    Been there and have any advice to share?
  • stamar
    • Apr 2011
    • 1362
    please show a picture of this.
    It is extremely unlikely they are compatible even if you make an adapter.
    • Kvasi
      • Apr 2011
      • 1122
      Why?
      Of course its doable, and ill prove you wrong in a few says..
      • Gregs///M
        • Mar 2012
        • 2459
        The fuel rail should mount to the injectors still but it wont bolt up to the intake manifold anymore. You can extend the mounting flange with some 1/8inch aluminum with holes for the 4 mounting holes.
        Should not be too hard if your good with metal and have the tools.
        Owner - Bavarian Restoration
        BMW and European Electronics Repair and Restoration
        www.BavRest.com
        My Feedback Thread
        Our Facebook!
        Follow our Instagram!
        • stamar
          • Apr 2011
          • 1362
          Originally posted by Kvasi
          Why?
          cool can you show a picture of what youre talking about?
          • Kvasi
            • Apr 2011
            • 1122
            Will post pics when i get on with mounting.
            Plan is to make aluminium with 2 x 45degree bends and some of theese to make shure i dont bend the injectors, since the fuelrail seems to be where wheere it bolts to the intake originally.
            Anyone know what size on those bolts, so i can by them before i pull things apart? M6 i guess?
            Have this shop at hand, so it should be doable :) http://www.maskineringas.no/maskinering/
            • Kvasi
              • Apr 2011
              • 1122
              Made another choice when i had it apart;
              Five-O 650cc (going in) vs Audi S6 300cc (going out)
              First some testcutting
              Then cutting
              Made theese from alu, they now sit between fuelrail and intake
              And the injectors in place
              • JrCamacho
                • Feb 2011
                • 618
                well played sir.
                • BergerNJ
                  • Oct 2009
                  • 349
                  game. set. match.
                  impressive yet simple work dude
                  • TobyB
                    • 5298
                    Of course, you checked to see that they were the right impedance first...
                    heh.
                    t
                    • Kvasi
                      • Apr 2011
                      • 1122
                      heh.
                      t
                      Yep :)
                      • Kvasi
                        • Apr 2011
                        • 1122
                        In case someone else should have a go at shorter injectors, keep on reading :)
                        Didnt see this coming, we have a collision
                        First some rethinking, then some redoing.
                        Made extenders
                        At their place in the fuelrail
                        And finally
                        • Cabriolet
                          • 9620
                          heh, saw the interference issue coming.
                          so you went though all this work of milling and such all to end up with the same overall size injectors? why not just buy the right size to start, and not put another possible failure spot in the system?
                          and you might hit the head with the injector rail.
                          Much wow
                          I hate 4 doors
                          • Kvasi
                            • Apr 2011
                            • 1122
                            No i did it to get larger (cc) injectors. Got theese cheap and i like working out problems, so thats why i did it.
                            Everything is now in place and works perfect.
                            • bmwstudent
                              • Sep 2011
                              • 1364
                              Problem solving leads to large brains. Nice job on the mod Kvasi.
