quick 2.7i wiring question
  • squidmaster
    • Aug 2011
    • 2666
    (coming from wire #6. There are two identical plugs. I've tried both.)
    (As a side note, look at this shit. The other plug is completely broken apart. Only the wires remain.)
    • e30trooper
      • 11576
      is that coming from the harness?
      • squidmaster
        • Aug 2011
        • 2666
        I tested two distr., cps, and wiresets from the e, but neither of them had a plug from wire 6, and neither sparked.
        • squidmaster
          • Aug 2011
          • 2666
          Nope, that's coming from the bell housing.
          flywheel sensor I believe.
          plugged in either of them (both are plugged into the bell housing right next to each other) into one or the other port. the open port I used for #6.
          • squidmaster
            • Aug 2011
            • 2666
            even with the e afm, I should be able to fire it up, it would just die immediately after, right? if I've read correctly?
            • ForcedFirebird
              • Feb 2007
              • 8300
              Wow, lots of posts. It's easier to read if you edit the post instead of making more lol
              The sensors in your bell-housing will no longer be used. You need the CPS with the toothed reluctor wheel on the end of the crank. The pulley is attached to it via 6 13mm hex head screws. Then there's a small bracket that holds the sensor in place. If you didn't change that crank pulley, the ECU has no idea the engine is turning, so it doesn't send a signal to the coil to fire. The bracket that holds the sensor is #12 in this pic. If you are trying to use #11 as your sensor, it needs to be changed from the is motor, along with the crank pulleys (and water pump pulley or your belt size will change).
              http://realoem.com/bmw/showparts.do?...05&hg=11&fg=10
              john@m20guru.com
              Links:
              • squidmaster
                • Aug 2011
                • 2666
                Yep, that's what I forgot to do. Swap over to the toothed crank pulley....
                Had to leave the car for a few more days. I'll be back on it maybe thursday.
                One last question, though: can I use the e afm at all? Or do I have to buy the i afm in order for it to run. Seems like I could just wire up resistors to give the feedback that the i afm would produce to at least limp around on.
                • ForcedFirebird
                  • Feb 2007
                  • 8300
                  ETA AFM will not work. See post #26...
                  john@m20guru.com
                  Links:
                  • squidmaster
                    • Aug 2011
                    • 2666
                    Amazing job. I'm jealous about your sense of cleanliness. My car is a mess.
                    I notice you kept the e cams. Are you planning on going with a F/I setup?
                    • ForcedFirebird
                      • Feb 2007
                      • 8300
                      No, I used the "i" cam. Since then I shaved the head .015" and used a .050" custom gasket.
                      john@m20guru.com
                      Links:
                      • squidmaster
                        • Aug 2011
                        • 2666
                        I cams bevel out, the e cams are nearly flat. My I cams look completely different from yours at least.
                        • ForcedFirebird
                          • Feb 2007
                          • 8300
                          What?
                          Perhaps if the lobes were wiped.
                          The e cam has less duration and MORE lift.
                          Wrong info.
                          john@m20guru.com
                          Links:
                          • squidmaster
                            • Aug 2011
                            • 2666
                            guh, excuse me, I have no idea how I didn't notice what I was saying.
                            I meant e pistons.
                            • ForcedFirebird
                              • Feb 2007
                              • 8300
                              Lol
                              The eta pistons and 885 top end makes 8.4:1 compression. I used a thinner head gasket and shaved the head to get it back up to the b25 compression. Building a new motor now using eta crank/rods, i pistons and shaved block. Shooting for 11:1 when it's done.
                              john@m20guru.com
                              Links:
                              • e30trooper
                                • 11576
                                Originally posted by ForcedFirebird
                                Lol
                                make a thread. the rings in my eta block are going fast. ( burning madd oil past 5k ) I figure time just just build a block now.
