What can cause this?
  • 5Toes
    • 9836
    So I reinstalled my starter with a washer on each bolt (between the bellhousing and starter) and it is still grinding. Any ideas at all? This carnage is from before I pit the washers on
    Would like to finish this tonight!
  • Cabriolet
    • 9620
    its not able to engage bc there is too much space. take the washer out.
    Much wow
    I hate 4 doors
    • 5Toes
      • 9836
      It grinds that way without the washers
      • 5Toes
        • 9836
        Car starts fine. Starter engages good. It just grinds
        • Wh33lhop
          • 11705
          How long has it been happening, and how new is your starter?
          paint sucks
          • gazellebeigem3
            • Jun 2005
            • 3712
            What were you doing prior to this? Did you install a new clutch or something?
            • 5Toes
              • 9836
              Engine swap.
              Starter is original to engine. My 5 month old starter is in the car now. Still grinds :(
              • Balleristic31
                • Aug 2009
                • 4198
                Did u instal plate between trans and engine?
                -NICK
                • F34R
                  sLaughter
                  • 12376
                  Gummy bears?
                  Instagram: @BWeissLeather
                  Current cars:
                  ~ '87 325 M30B35 swap
                  ~ '87 535
                  ~ 01 540 Msport 6spd
                  ~ '06 X5 4.8is
                  • 5Toes
                    • 9836
                    Yes the flywheel and the spacer, and the flex plate for the torque converter are installed the correct way
                    I put the spacer on, then the flywheel, and the the torque converter plate. Torqued all the bolts the correct way.
                    Also the thin plate that goes between the bell housing and the engine block is installed. It is not rubbing at all, I have checked
                    • Jparkr
                      HR Admin
                      • Jan 2006
                      • 3494
                      Haven't really dealt with too many Automatics but from what I remember...
                      It's Flywheel, then spacer, then triangle plate for the torque converter.
                      Sounds like you have your flywheel spaced incorrectly or you may have something installed backwards, I remember the automatic's flywheel being very small compared to the 5spd's so you may have put it on 180.
                      Ether way, your taking all that shit apart again.
                      1987 PRO-3 car /1990 325is (2.7i Concours)
                      • Balleristic31
                        • Aug 2009
                        • 4198
                        This is what I was talking about
                        Maybe get new starter
                        -NICK
                        • 5Toes
                          • 9836
                          Well it is too close to the starter now. If I put the spacer after the flywheel.. then it will be even closer and not work at all.
                          I don't mind pulling the starter. Is there anything I could have not installed?
                          • TimKninja
                            • 2131
                            BROMANDUDEGUY.
                            Drop your trans. We can't tell when you borked up, sounds like you missed something. sounds like your flywheel isn't hitting your starter right.
                            1985 325e M50TU(Sold)
                            1991 318is Slicktop (Sold)
                            1990 325is Brilliantrot S50/5 Lug Swapped.
                            1992 525i Manual shitbox Winter Beater
                            • 5Toes
                              • 9836
                              Nobody can think of something I may have missed?
                              I would rather not drop the trans, it takes so much work, and I may have everything right down there
