I have some advice, don't post a starter question in the general discussion forum. KTHX
What can cause this?
I have seen them grind from load, where the starter's motor would grind because it couldnt take load - now, I dont think that is happening here because it's two starters and one is fairly new. Can you get a set of calipers in to measure the distance between the block and wheel?1987 Delphin 325e Sedan - Natalie
1990 325i 24v
1997 Chevrolet K1500 Crew Cab 4x4 - The CenturionComment
I can't see the starter mounting as being the problem when suing the original starter. Thus I'd say the problem is in the bell housing. The correct assembly order is flywheel, spacer, and then flex plate. It would be pretty obvious if the flywheel for a manual transmission was in backwards, but it seems to me you could get the flywheel for an auto in backwards.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, ALComment
According to realoem the correct order is flywheel, spacer, flexplate.
http://www.realoem.com/bmw/showparts...37&hg=11&fg=20Comment
that is odd...-FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
-The Beauty in the Tragedy-
MECHANIC SMASH!!- (you all know you do it)
Got Drop?? ;-)
Originally posted by JinormusJBut of course
E30s are know to be notoriously really really really ridiculously good lookingComment
