Unpleasant surprise while cleaning pistons
  • sleepy350
    • Feb 2011
    • 127
    Hey guys, today in anticipation of picking my head up from the machine shop, I decided to clean 205,000 miles of crud and carbon built up on my piston tops.
    Everything looked good, I can even clearly see the original crosshatching on the cylinder walls. Even more surprising I managed to get my GF to help out.
    But then I got to cylinder #5.....
    Take a look at what I found.
    I have no idea what happened here, I don't even remember any marks in the combustion chamber in the head. I'll have to wait till I pick up my head to be sure.
    I'm expecting to have to replace the piston. Are there any other things I should look into after finding this kind of damage?
    -1988 BMW 325is - Sold
    -1991 BMW 535i - Parted out
    -1994 BMW 530i/5 - Sold
    -1970 Chevy C10/LWB
    -1973 Chevy C10/SWB stepside
    -1984 Chevy C10/LWB
    -2008 R56 MCS - Dead
    -2018 Toyota Tacoma TRD-OR DCLB
  • TurboJake
    • 3780
    You're already on top of the head, so check the cylinder wall really closely.
    Leave Me Transaction Feedback
    • FLG
      • Sep 2011
      • 3165
      IMO
      If the cylinder wall is fine, knock down the nicks as best you could and it should be fine, looks very minor.
      Any idea on the cause?
      Sent from my Galaxy Nexus using Tapatalk 2
      -Build http://www.r3vlimited.com/board/showthread.php?t=295277
      • Northern
        I like cupcakes & sh!tboxes
        • 5234
        Could have dropped a valve a while back from whatever reason and a PO or shop could have called it good enough and thrown it back together.
        Originally posted by priapism
        Originally posted by shameson
        • nomansland92
          • 1657
          Mine has the same on 2 of the pistons and the head but not just as bad. Walls were in great shape also, i would also just fix it the best you can and run it.
          IX being restored here
          Ix turbo build here
          • bmwstudent
            • Sep 2011
            • 1364
            Originally posted by FLG
            IMO
            exactly
            • sleepy350
              • Feb 2011
              • 127
              IMO
              No idea of the cause at this point, no debris, no shards, in fact I had no idea the damage was even there until I cleaned up all the carbon. Will look at the head later and look for any signs of damage.
              -1970 Chevy C10/LWB
              -1984 Chevy C10/LWB
              • TobyB
                • 5258
                yummm... ate something. Only real dangers are hotspots causing detonation,
                and upper ring land compression causing ring breakage.
                Do knock the high spots off... and check the walls again. You're looking
                for fine (but deep) scoring that the ring ends leave...
                t
                • sleepy350
                  • Feb 2011
                  • 127
                  t
                  Looks like you're right. Look what I found when I picked my head up from the machine shop.
                  -1970 Chevy C10/LWB
                  -1984 Chevy C10/LWB
