I bought this motor from a guy who had rebuilt it after snapping the timing belt, but he must have installed the piston rings wrongs as the compression is between 50-75 for all six cylinders. I need to do a rebuild and am trying to make sure my CR will be correct.
It is a m20B25 with 885 head and forged pistons and rods from Ross Racing. Supposedly the CR is calculated to be 9.75:1 for this application (was a euro m20 with the longer piston length) but I am looking at the specs and it seems something is off, perhaps I am misunderstanding this.
I am getting my specs from the piston manufacturer (Ross Racing) and this website:
http://web.archive.org/web/200505261...Mahle_m20.html
The Euro i motor should have a stroke of 75mm and a rod length of 135 mm, but the specs emailed to me from ross are as follows:
Stroke 3.528”
Rod 5.315”
Block height 8.110”
effective crown volume of -5 cubic centimeters.
The combustion chamber figured was 42 cc’s, and the crankshaft stroke was 3.528”. the conversion to MM requires that you divide by .03937.
The 206 mm, or 8.1" height is right. I guess the stroke is throwing me off because it should be 75 mm, or maybe 81 mm (3.1"), not 3.5" or 89.6 mm.
Was the engine calculated for another crankshaft? I did some research and it looks like the M54B30 has that crank and that is forged and would make sense to match the forged pistons and rods.
Thanks I may have answered my own question but somewhat doubt the previous owner would have the knowledge to find, buy and install the correct 89.6mm crank, hell, he had an eta head on it to begin with!
Stroke 3.528”
Rod 5.315”
Block height 8.110”
