17lb or 19lb for A Stock 325i
  • Quinthirty
    • Mar 2012
    • 318
    Hi, I was trying to search for a comparison between 17lb and 19lb injector performance, but couldn't find any. My objective is to make the M20B25 perform optimally, considering both fuel economy and ample power in mind. I'm moving towards replacing the chip with one of those ebay ones, and also plan to replace the worn out injectors with it.
    I want to know more about your experience with both 17lbs or 19lbs injectors specifically MPG and power.
    Thanks in advance!
    Mine is an A/T by the way.
  • Earendil
    • 1662
    Stock motor, stock injectors. But clean well functioning injectors will make a huge difference!
    Rather a pity (and yet awesome) that BMW designed these cars with no giant bottlenecks, and very very few tiny ones. The injectors are not a bottle neck if they are operating properly. And before anyone says I'm wrong, The Pro-3 racers run stock injectors and pull above stock HP figures from their cars.
    1989 - E30 - M20B25 - Manual. Approx 300,000+ miles - Track Rat & Weekend Fun
    2000 - E46 - M52TUB28 - Manual. Approx 130,000 miles - [not so] Daily Driver
    I'm looking for a Lachssilber Passenger Fender and Hood. PM if you have one or both to sell!
    • mbonanni
      • Sep 2011
      • 6236
        • 37834
        I recommend the 17lb M50 injectors to anyone with a M20 engine. Otherwise keep them stock.
        Grover Beach, California
        BimmerHeads.com
        • BMW_325i
          • 61
          Would that be part # 0280150415?
          I have these and could never get a definitive aswer as to whether they are 17, 18 or 19lb/hr at 3 Bar.
          1988 Lachssilber E30 325i sedan.
          Factory fit-out: manual; SILBER LEDER; M SPORT SUSPENSION.
          Modifications so far: Miller MAF + 19# ECU; Ford 19# Design 3 injectors; IE adjustable FPR; KAMotors CF airbox; IM MTX-L; EBC Greenstuff.
          Retired - '83 Arctic Blue E28 528i powered by M30B32
          • sayed ali
            • 762
            19lb from m30 (black ones) + m30 afm + Ebay chip would be a good combo ..
            M20B28 Turbo
            My Build Thread
            http://www.r3vlimited.com/board/showthread.php?t=255839
            • Sagaris
              • Sep 2009
              • 2243
              There is no benefit to running old style single pintle 19# injectors. Get Bosch Design III injectors if you insist on running 19# injectors.
              There is a reason that car companies don't just run 100# injectors on everything just to save money. Running injectors which have a lower maximum flow rate allows a much broader spectrum of injector pulse widths to be used to deliver fuel between idle and WOT. An injector with a higher flow rate will be less precise. It is much more difficult to achieve a good idle with high flow rate injectors ("high" flow rate = relative to the amount of air the engine can move)
              There is definitely a benefit to running the M50 17.5# Design II injectors from an M50 or even 19# injectors as long as they are Design III due to their improved ability to atomize fuel which comes from multiple pintles, better pintle cap and internal nozzle design. The optimal scenario would be to run some 14.5# which have the improved design characteristics that the Design II and III's have. I do not know the availability of such injector.
              Like MR325 said, run a set of rebuilt 17.5# M50 injectors and better yet, get a MarkD chip, not those stolen Dinan clone chips that only change the full throttle maps. Instead of an M30 AFM, get a refurbished M20 AFM.
                • 34847
                Originally posted by Sagaris
                Im sorry to say this but if you are telling anyone to use 19# injectors on a stock M20 and are not specifically saying 19# Bosch Design III injectors then I invite you to justify your reasoning.
                agreed.. sortof.
                this isn't really true. the problem isnt' that the injector is less precise (some of the common large injectors are extremely precise and very fast), it's that your injector PW at idle gets close and closer to the "dead time" of the injector, or the time that it takes to actually open and close the pintles. when you get into this region, fuel flow becomes non-linear and you end up with an unstable, difficult to tune idle.
                however... you will NOT run into that on an M20 until you get to very large injectors, over 42# or so, but even some of the 60# high-z injectors have response times under 1ms, which could still have a quite good idle. Not that you'd want to try to run 60# on Motronic 1.3, but to say that large injectors are less precise or that you can't idle with anything over 19# is completely wrong.
                agreed
                • nomansland92
                  • 1657
                  I ran m50 green tops with my stock M20 and there was a nice improvement. I think it even help my mpg a little. I would recommend them and they can be used with the stock chip, anything bigger like those 19lb ebay ones aren't going to do any good unless you run a chip and a good afm or even better a maf.
                  IX being restored here
                  Ix turbo build here
                  • redsubdivisions
                    • Feb 2011
                    • 1762
                    17lb M50 injectors, 4.10 LSD, and a fleabay chip on my sedan. I noticed a difference...not turbo car fast, but still improvement enough for daily driving. it also seems the car runs a little bit smoother and uses a little bit less gas. Could be just my mind, though. either way, I thought it was a nice upgrade.
                    1989 325i - 2.7i, Holset H1C, 60lb injectors, whodwho MS-PNP.
                    2012 Passat TDI - DD Duty
                    2008 GMC Yukon XL Denali - Kiddie hauler/grocery getter
                    • AutoXinE30
                      • Aug 2007
                      • 277
                      I used 19lb(199cc) Bosch 4pintle injectors from a 5cyl FWD Volvo on my DIYPNP 325i. Only other mods were, deleted AFM and 2.5in exhaust after the cat. I pulled many extras and I can grab the PN when I go home if you want it.
                      Didn't really feel much of a difference between the stock injectors to 19lb injectors through the MS but, I did like the fact that my duty cycle wasn't in the 90's anymore.
                      I did like the fact they are much quieter then the OEM ones were though.
                      • Gregs///M
                        • Mar 2012
                        • 2459
                        I run the plastic body Bosch #17 design III. They gave me more low end torque, better gas mileage, and better idle. I recommend them.
                        Owner - Bavarian Restoration
                        BMW and European Electronics Repair and Restoration
                        www.BavRest.com
                        My Feedback Thread
                        Our Facebook!
                        Follow our Instagram!
                        • kman_e30
                          • May 2007
                          • 573
                          how did you go about deleting the afm? special tune?
                          84 318i drift car
                          04 mk4 gti 1.8t
                          96 e320
                          63 plymouth valiant
                            • 34847
                            MS = megasquirt
                            • fatsooo
                              • 312
                              read a bunch of threads when considering switching mine up
                              ill make it real simple like above
                              17# for stock chip, some aftermarket chips run 17# too
                              19# for aftermarket chip only.
                              your choice of chip is up to you, but im gunna be saving up for a markd chip as opposed to ebay
                              i have the 17# m50 injectors i bought rebuilt from a forum member so i can just use these until i save up for the chip
