Cams and a Tune
  • m3/e30fanatic
    • May 2011
    • 2969
    Cams and a Tune
    I bought my car with 272 ie cams. and i was looking into getting a ecu chip but i heard if you have cams you have a tune. is this true? do i already have a tune?
  • TobyB
    • 5280
    Not true. Do you have a tune? Can you CARRY a tune???
    Open your ecu and look at the chip... that or rev it 'till it hits
    the limiter and see if it's over stock...
    Where's the second cam? In the trunk?
    t
    • e30leigh
      • Mar 2012
      • 481
      lol
      if you have a cam (aftermarket cam, they have one from factory) you need a tune (a retune, they also have a tune from factory). you dont get a tune by installing a cam.
      • digger
        • Nov 2005
        • 6171
        t
        he said cams not camshafts so the camshaft has 12 cams on it one for each valve
        also the OP already has a tune, it came that way from the factory
        end being smartass/
          • 37833
          Open your ECU and take a look.
          Grover Beach, California
          BimmerHeads.com
          • m3/e30fanatic
            • May 2011
            • 2969
            ok i guess ill be busy open up my ecu this week.
            also how can i tell if i have a afm or maf? i have a huge k&n intake if that helps.
              • 37833
              This is an AFM:
              This is a MAF:
              BimmerHeads.com
              • m3/e30fanatic
                • May 2011
                • 2969
                Originally posted by MR 325
                This is an AFM:
                This is a MAF:
                i was just hanging out with danny at united artists starbucks and he said i have a chip so we're good :)
                how can i tell if i have cams or the past owner ripped me off. -.-
                and i believe i have stock afm. :(
                • e30leigh
                  • Mar 2012
                  • 481
                  take the cam cover off. have a look. see if you have more then one. or if the one you have is bigger then a stock one. but id be carefull many good men have had their teeth knocked out checking out another mans cam.
                  • The Humjet
                    • Jun 2010
                    • 528
                    Lol you made that sound very believable. You must have a lot of fun with the apprentices sending them away to get a long weight.
                    • pandaboo911
                      • 2070
                      If you bought the car thinking it has an aftermarket camshaft, without asking for receipts, it doesn't have an aftermarket camshaft.
                      • m3/e30fanatic
                        • May 2011
                        • 2969
                        oh joy, oh well :/
                        it sounds and feels like its cammed though. ill see i guess.
                        • m3/e30fanatic
                          • May 2011
                          • 2969
                          definately cammed compared it to a video of my friends e30 with similar mods and sounds identical. :) pretty happy
                          • TobyB
                            • 5280
                            If U like the car. all is good.
                            Unless it has an M50/52/s50/m42, you really DO only have one cam, though.
                            And next time U have it in 2nd gear, don't shift until it does 'dit- dit- dit'
                            If U are doing 6200 rpm (6700 for 318is) then U do not have a tune. Not even camptown races.
                            But if U see 6700 (7300 for 318is) U are in like Flynn.
                            Not that it matters, since U R happi!
                            all is good.
                            t
                            • e30leigh
                              • Mar 2012
                              • 481
                              a can of compression is my fav hahaha
