Schrick 284/272
  • jules325i
    • Jul 2011
    • 353
    Schrick 284/272
    Just wondering if the 284/272 willl clear stock pistons, With a brand new cylinder head.
    329i
  • einstein57
    • Jun 2007
    • 10780
    a 288 does. not sure why a 284/272 wouldn't
    www.gecoils.com
    • James Crivellone
      Head Janitor
      • 6305
      check your valve clearances. Many people (myself included) have had piston <-> valve contact with a stock bottom end running that cam.
      It did help force me into a 2.8L stroker motor though
      • jules325i
        • Jul 2011
        • 353
        Ill measure it myself to be sure, i was just wondering if it was a definite yes.
        I already have a stroker i don't need to be forced into another haha.
        This is a side project.
        329i
        • digger
          • Nov 2005
          • 6170
          shit fellas after recent events don't listen to any clever dick on this forum just check it yourself.
          also a 288 does not clear sufficient if the head and or block has been skimmed thats risky advice
          • jules325i
            • Jul 2011
            • 353
            Ill measure it myself for peace of mind.
            329i
            • DTMbimmer07
              • 1485
              It deffinetly clears the Seta bottom end, i can tell you that.
              • structured
                • 954
                yeah, as stated above, you just have to check.
                288 made contact in my motor.
                • CarsSuck
                  • Oct 2005
                  • 968
                  Digger is referencing RAXE, Acollela and Bmr all blowing up their fresh rebuilds within a couple months of each other because none of them actually measured clearances. All the motors ran for a few days and then blew shit. I know I won't be assembling my motor (whenever the fuck that happens ) without checking, no matter what cam I end up with.
                  --Will
                  • Bmr
                    • Jul 2009
                    • 322
                    +1 Exactly. ITs like pissin money down the drain if you dont measure.
                    • DTMbimmer07
                      • 1485
                      what head gasket were u running? bigger valves?
                        • 34844
                        I've been saying this for years and nobody ever seems to listen..
                        there's about a 85-90% chance they *might* clear just fine. on my original engine they were .01mm too tight.
                        But nobody can say they will definitely clear on a stock motor, not unless they offer to pay you for a new engine when it doesn't.
