M20 Main Bearing Differences and Compatibility
  • SkiFree
    • Jun 2011
    • 2766
    ---M20 – Early vs. Late main bearings. --------------------------------------
    *Early = ‘e’ blocks/ SINGLE TANG
    *Late = ‘I’ blocks/ DOUBLE TANG
    Here’s a picture of the difference between the 2 style main bearings
    (note that these particular bearings have been coated).
    You can see the ‘e’ main bearings (LEFT) have single “tangs” at either end that line up with the block and saddle. The ‘I’ main bearing (right) has a saddle ½ shell that is smooth (no oil journal) and has a double “tang”, but the top ½ shell is the same as the “early” style.
    ------Combinations and why it may matter.---------------------------------------
    Why might it matter?
    It does come down to availability (NOT performance). BMW used both Kobenshmidt and Glyco as OEM suppliers, which are carried by your preferred vendor (Ireland Engineering, Guten Parts, Blunt, Korman, Metric Mech., AZ Autohaus, etc.) or shop doing the work (TCMotorsports, Castro, Midnight Oil, Heritage Motorsports, Midnight Motorsports, E30 Motorwerks, etc.).
    THE SET THAT IS NO LONGER AVAILABLE (NLA) IS THE ‘EARLY STYLE “e”’ .25-UNDER & .50-UNDER BEARINGs. All other bearing sets are still available at this time (7/19/12).
    ----Compatibility/Solutions?------------------------------------------------------
    Contrary to what WORLDPAC states, you CANNOT simply retrofit a late bearing set into an early block (this has been the source of a fair amount of recent misinformation). See the picture below, the tang’s width is different and you would need to cut another tang slot in each of the bearing saddles to accommodate the second tang, the risk is too high to consider.
    The BEST solution for the individual seeking NLA undersize single-tang bearings for their M20 ‘e’ block, is to purchase 2 sets of late “I” bearings and simply pair up the halves that have the oiling-groove in them. See picture.
    Which M20 Compatible crank you have (b27,b25,m50/2,s50/2) has nothing to do with what style main bearing you need (other than sizing obviously).
    If anything is unclear, feel free to ask. Hopefully someone can sticky (or put in DIY Section) this to avoid later confusion.
    - Andrew @ Ireland Engineering
    ADAMS Autosport
    • 37834
    Andrew, this is awesome. Thanks for posting!
    Grover Beach, California
    BimmerHeads.com
    • bmwstudent
      • Sep 2011
      • 1364
      Yes thanks, jlevie gave me what i needed to know yesterday but this is definitely great info. Thanks,Skifree
      • 88SuperETABD
        • Apr 2009
        • 911
        Does IE have the early coated bearings in stock?? I need a set for my build, we've talked about it. You say theyre NLA. Am I Screwed?
        (SOLD) 1988 327i Build Thread: http://www.r3vlimited.com/board/showthread.php?t=155086
        1970 Gruppe 2 2902 M20 Turbo Build: http://www.r3vlimited.com/board/showthread.php?t=373891
          While it may have changed in the last few months, the bearings for all colors for nominal journal dimensions were available a few months ago. I'd hesitate to re-grind a crank as it is too easy to get a used one that only needs polishing, so I don't know about the availability of the undersize bearings.
          If you want coated bearings, you first need to measure the journal dimensions. Next talk to who will be coating the bearings to see what the coating thickness will be. Then pick the color that will result in the correct clearance.
          • Chruby99
            • May 2011
            • 262
            So to run a 360 groove on a late block we need to get 2 sets of late bearings and run the grooved bearing on the block and cap
            • SkiFree
              • Jun 2011
              • 2766
              Sorry if it was unclear, undersized (.25 and .50mm) early bearings are NLA. Replacement sets can be pieced together by using using 2 similarly sized late sets.
              Standard size early bearings are still readily available. I've got 5 coated std. size early sets on the shelf.
              As for under-sizing the crank. I'm with Jim. Any M20 cast crank that is ground undersized (not just polished) needs to be nitrated (will have a blue hue).
              ADAMS Autosport
              • SkiFree
                • Jun 2011
                • 2766
                In my mind that would be going backwards. There would be no noticeable gain in doing so.
                Early style - 360' oil groove with single tangs
                Late style - 180' (top half) with oil groove and smooth bottom with dual tangs.
                To go from a late to early bearing configuration you'd need the block main-caps from the early block and they tend to be matched to the block from the factory.
                ADAMS Autosport
                • TobyB
                  • 5298
                  Yeah, you can't swap caps on a block. It just doesn't work. Without some significant machining.
                  Tang.
                  t
                  • digger
                    • Nov 2005
                    • 6213
                    any quality differences or preferences between OEM, KS or Glyco main bearings? what do you get if you go OEM?i guess same question with rod bearings?
                    obviously OEM are more $$$ so neglecting that whats the deal? for a stock engine i wouldn't care but for a performance build which is better?
                    not looking for fancy coated bearings, may consider ACL for the rods if i can find a set but i hear they closed down.
                    current engine uses KS for mains and rods, no known issues
                    • SkiFree
                      • Jun 2011
                      • 2766
                      ... no difference in quality of the bearings themselves. Some reason I gravitate towards KS's, merely for the fact that they seem to be consistently packaged more snugly.
                      ADAMS Autosport
                      • digger
                        • Nov 2005
                        • 6213
                        for some reason im leaning towards KS, dont know why maybe because Kolbenschmidt sounds more german
                        • jeffnhiscars
                          • Jun 2011
                          • 6011
                          Lol...that's how I make lots of buying decisions
                          Alice the Time Capsule
                          • itsonlygeorge
                            • Feb 2014
                            • 852
                            Sticky!
                            1987 325e Lachssilber w/ MarkD chip and late bumpers, Zender EVO spoiler, s3.25 LSD
                            Originally posted by nando
                            I don't think there's really strong evidence that ZDDP harms cats.
