Sudden death on highway.
  • Mr. Burns
    • Aug 2011
    • 3516
    Cruising in my "reliable" e30(not the turbo). Doing about 65mph, and I get a noticeable stumble...wtf.
    Check engine comes on, engine still running....
    I let off the accelerator and the cel disappears.
    Hmm
    Think nothing of it, cruise carefully at 50mph for another 10 minutes.
    Slow down for a red light, idle now at 300-400....ruhroh...
    Try to accelerate, and won't have it.
    Stumbles, hesitates, bitches whines and dies... Coast to the shoulder of the road, check everything... Nothing out of place.
    Call for a tow, do stomp test in meantime.
    Results are : 1221
    Leads to bad oxygen sensor?
    Don't they normally give more notice than a sudden highway suicide?
    Anything else a 1221 code can mean?
    Originally posted by flyboyx
    i have watched my dog lick himself off a few times
  • Mr. Burns
    • Aug 2011
    • 3516
    And to add, car will not start will turn over yet not catch. It wants to, but won't maintain. Just does.
    Recently replaced:
    885 head full rebuild
    Distributor cap and rotor
    Spark plugs
    Spark plug wires
    Thermostat
    Was running perfect until today.
    • M-technik-3
      • 18946
      break a rocker?
      • Mr. Burns
        • Aug 2011
        • 3516
        • Cronopoulos
          • Jul 2011
          • 2187
          He is referring to a rocker arm located under your valve cover.
          Project log -- DIRTY 30
          2.7i * Megasquirt tuned * E85 powered
          • BAlbertiX
            • Apr 2011
            • 247
            I had two similar stories, one due to a clogged cat which clogged suddenly on the highway. Complete loss in power, 50mph max on highway and from idle the car was doggin hard. Did you hear any rattling under the car?
            Second, a seized bearing. Any screeching from the engine while trying to turn the car over?
            '87 325is coupe
            previous:
            '91 325iX coupe
            '86 325e sedan
            • kingston
              • Jun 2010
              • 2669
              Do you have spark? Coil may have just crapped out
              Originally posted by LJ851
              kingston is the play by play announcer for this thread.
              ‘Tis by the grace of God that my cars run!
              Originally posted by unloadedak
              #teamross
              Siobhan's Build Thread - UPDATED!
              • maniacmatt
                • Feb 2007
                • 483
                That 1221 code just means that the o2 sensor is giving the ECU values that are outside of an acceptable range. It doesn't necessarily mean the sensor is at fault. Anything that could cause the engine to run very rich or very lean would cause the CEL to throw the 1221 lambda code. A faulty o2 sensor is very unlikely to cause the car not to start.
                Assuming the car has an m20 broken rocker as stated above is a good possibility. You could also check the fuel pressure as the FPR or fuel pump could be at fault. A stuck or faulty AFM is also a possibility.
                • F34R
                  sLaughter
                  • 12385
                  Originally posted by M-technik-3
                  break a rocker?
                  Brother broke two rockers in his b25, ran badly but ran.
                  I am thinking the coil on the fire wall.
                  Instagram: @BWeissLeather
                  Current cars:
                  ~ '87 325 M30B35 swap
                  ~ '87 535
                  ~ 01 540 Msport 6spd
                  ~ '06 X5 4.8is
                  • Mr. Burns
                    • Aug 2011
                    • 3516
                    Oh, sorry. My brain went strait to rocker panel.
                    Couldnt be that, would sound like catastrophic failure if anything.
                    This failure was weak and fairly quiet.
                    I'll check for spark at the coil. Good call.
                    • Mr. Burns
                      • Aug 2011
                      • 3516
                      Just checked spark, all I good. Turned engine over, started 1st shot flawlessly.
                      Idled fine. Gave it some gas, stumbled.
                      I did take notice however that my fuel filter flap was dangling after I may of ht some road debris the other week(styrofoam blocks)
                      Also, torrential downpours here lately.
                      Fuel pump seems to work fine, feeds engine while in acc ( hear the humming)
                      So Coles:
                      Cold starts fine, will rev up to 7k with no issue.
                      After a couple minutes will start to complain.
                      Several bursts of rev's is when it'll choke up....
                      • nokincy
                        • Feb 2012
                        • 302
                        Have you tried running it with the O2 sensor unplugged?
                        • Mr. Burns
                          • Aug 2011
                          • 3516
                          No. Still too warm to meddle with exhaust. Will wait till tomorrow.
                            As stated above a 1221 (or a 1222) code can be the result of an upset in the A/F ratio. In this case my first suspect would be a fuel system problem since the engine will start but not run well above idle. A check of the rail fuel pressure would be the first thing I'd do.
                            • Mr. Burns
                              • Aug 2011
                              • 3516
                              Fuel rail pressure.
                              Can this be checked with compression tester?
