What is this?
  • EuroTrash///E30
    • 128
    What is this?
    I took off my water pump and this fell off. I dont know what it is.
  • cabriodster87
    • Jan 2011
    • 1042
    http://www.realoem.com/bmw/showparts...65&hg=11&fg=25
    compression spring and pin #18 & 19
    Reich und Roll!
    • bmwguy325is
      • May 2011
      • 1263
      Its not to important. Only helps the timing belt...........
      sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
      The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
      • Cronopoulos
        • Jul 2011
        • 2187
        Have you run the motor since that fell off? Make sure that goes back on... also check your timing.
        Project log -- DIRTY 30
        2.7i * Megasquirt tuned * E85 powered
        • EuroTrash///E30
          • 128
          No, i havent ran it since it fell off, the engine is apart right now. Why did it come off when i removed the water pump?
          • bmwguy325is
            • May 2011
            • 1263
            There is a notch in the water pump. It rests against it.
            • EuroTrash///E30
              • 128
              I found the notch in the water pump, but I dont see how i get the water pump on with the compression spring and pin on it. Ive looked and on the diagram on realoem.com doesnt match my pully.
              • bmwguy325is
                • May 2011
                • 1263
                Sounds like you are in above your head.
                I have ussed a pair of needle nose plies (vise grip preffered) to compress the the spring and slip it in after I have the pump on.
                Other wise you have to hold the pump and fish in the bolts. Which I have done roadside.
                May I amend this with I am impressed you got the fan clutch off.
                • EuroTrash///E30
                  • 128
                  Yeah, its my first water pump for an e30. So im kinda in over my head, but im trying not to mess it up. I got it back on, Thank you
                  • TobyB
                    • 5280
                    If the tensioner is bolted down solidly, it's not super critical-
                    it sets the timing belt tension as you're installing it.
                    Then it just sits there. I guess it acts as a bit of a safety...
                    but if that bolt loosens, you don't have long before things... fall apart...
                    t
