Camshaft management?
  • F34R
    sLaughter
    • 12376
    I am doing the i conversion on my SETA and I bought a Schrick 288 camshaft for the refresh on the head. Long term; I plan on MS3 and wasted spark to replace the old BMW brains.
    My question is: Do I need a chip or something to make use of this more aggressive cam till I get a custom built tune?
    Instagram: @BWeissLeather
    Current cars:
    ~ '87 325 M30B35 swap
    ~ '87 535
    ~ 01 540 Msport 6spd
    ~ '06 X5 4.8is
    • 37832
    A performance chip would help but it's not required.
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • sayed ali
      • 762
      Better to have a chip for that cam ...
      M20B28 Turbo
      My Build Thread
      http://www.r3vlimited.com/board/showthread.php?t=255839
      • structured
        • 954
        I installed a schrick 288 in my SETA and measured the clearance only to find that the valves were making contact. Make sure to check before you run it.
          • 34839
          Double emphasis on this post
          • Exodus_2pt0
            • 5943
            Triple. Even if 20 people run a cam with no issues, and even if you turn it over by hand and it doesn't hit, it just might happen when running.
            No E30 Club
            • TobyB
              • 5265
              $1.95 spent on modelling clay can save you hundreds later... plus dozens of hours...
              t
                • 34839
                Or $5 on a dial indicator from hf
                  Clearance can be measured that way, but a lot of care must be taken to ensure that you have accurate numbers. Putting clay on the pistons and rotating the engine through a revolution is simpler, more direct, and less ambigous.
