Intermittent Starting, one stall today
  • saturnv7890
    • Jan 2011
    • 696
    Sor reference for those looking back on this thread:
    Starter solenoid going bad, replace starter (like said)
    The stall was due to intake leaks
    Problem:
    The car will sometimes just not start at all. I'll turn the key, nothing will happen except the dash lights turn on.
    This used to happen like once a week or so, now it's like every few starts.
    Sometimes I'll wait a second, be frustrated, then turn the key again and it turns on.
    Sometimes I'll keep trying and then after like 5 minutes it'll start no problem.
    Sometimes I'll wiggle the c101 and it'll turn on after I turn the key again, but there's no way of knowing that that does anything.
    Today my car just shut off as I was coasting to an intersection. I came to a stop, tried to start it up, it did not crank like usual. It wasn't until I pushed it in the gas station with the help of a random fellow bmw owner, and I called aaa and a tow truck was on the way that the car started up like nothing had happened.
    That was the first time it's done that, and I'm not sure if its related.
    It seems the car has a mind of its own and only cranks/starts when it feels like it.
    I've replaced a few different parts this summer including the c191 fuel injector harness (unrelated bucking issues), crank position sensor, fuel pump, main relay (cleaned relay contacts), fuel pump relay, fpr.
    Any input is greatly appreciated!
    My Transaction Feedback
    My "build" thread
    BUY MY CAR!!
  • Gregs///M
    • Mar 2012
    • 2459
    Starter solenoid fails more often when hot. Replace starter.
    I had the same problems. Sometimes would not start after driving car for a while. Starts up every time in the morning tho. I replaced the starter with integrated solenoid and problem vanished.
    Owner - Bavarian Restoration
    BMW and European Electronics Repair and Restoration
    www.BavRest.com
    My Feedback Thread
    Our Facebook!
    Follow our Instagram!
    • dnguyen1963
      • Nov 2011
      • 2651
      With your car shutting off while coasting I would check all grounds in your car.
      • saturnv7890
        • Jan 2011
        • 696
        damn, well i'm not gonna find $200 lying around :/
        Wheres the cheapest most reliable source for those things?
        Do you know which grounds I should be looking at?
        My "build" thread
        BUY MY CAR!!
        • dnguyen1963
          • Nov 2011
          • 2651
          Table t, chapter 15 in the Bentley manual.
          • saturnv7890
            • Jan 2011
            • 696
            will take a look! I already replaced the engine ground this summer, I'll just have to test them all i guess?
            My "build" thread
            BUY MY CAR!!
            • dnguyen1963
              • Nov 2011
              • 2651
              Yep. These cars are getting old. The grounds can be quite corroded.
