Vacuum gauge readings
  • packratbimmer
    • Dec 2009
    • 1335
    I just threw the vacuum gauge on my M20 in the 325iX and got an alarming 11 reading. I would expect 15-20. Has anyone established a "baseline" for the M20? I don't want to start chasing vacuum leaks if this reading is normal. Thanks
    The only way to "chase intake leaks" is to have a shop run a smoke test.
    • packratbimmer
      • Dec 2009
      • 1335
      Trust me, I read all the other threads. Much can be learned from a vacuum gauge. Why would I want to pay for a smoke test if I don't need one. A vacuum reading will provide good baseline. I just do t know if 11 is too low for a stock 325i engine. Seems too low
      • Dj Buttchug
        • Jun 2010
        • 7686
        we need more info. What is your current elevation? also is the engine in closed loop or open?
        Turbo M42 Build Thread :Here
        Ig:ryno_pzk
        I like the tuna here.
        Originally posted by lambo
        • lcoleman
          • Jan 2009
          • 331
          I agree with jlevie that you are going about this the wrong way, but referenced off the FPR I was seeing more like 15-18 inHg at a strong idle.
          • packratbimmer
            • Dec 2009
            • 1335
            Bingo! 15-18 That is all I need to know. Thanks
