Im not getting a response from the stomp test indicating the tps; is the TPS serviceable or do I need to just replace it?
Tps
Tags: None
Save yourself the headach and replace it. I need to do this to my m50 as well. Stomp test does nothing on mine and I have intermittent driveability issues occasionally.-Andy
I pulled 2 throttle bodies recently, replaced the TB heater gasket, etc and drilled the hole & cleaned the TPS with electric contact cleaner. It seemed to help plus I found out one was dead on WOT. Its $3 in gaskets and maybe half an hourSeat Shocks....I have passed the baton to John Christy from Ninestitch. Email John or Garrett at ninestitch1@gmail.com
Alice the Time Capsule
87 Zinno Cabrio barn find 98k and still smells like a barn. Build thread http://www.r3vlimited.com/board/show...20#post3455220Comment
Yes the TPS will cause hard starting, idle issues, no stomp test, and a variety of other problems.
Replacement is usually not necessary unless you verify it is adjusted correctly first. Check with the Bentley repair manual on how to adjust and test.Owner - Bavarian Restoration
BMW and European Electronics Repair and Restoration
www.BavRest.com
My Feedback Thread
Our Facebook!
Follow our Instagram!
The TPS is correctly adjusted if the idle switch closes when the throttle arm is 1mm off the stop screw. You can't just by the click and need to use a meter or test light to tell when the idle switch closes.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, ALComment
