M20 head plastic bit?
  • Andy348
    • Sep 2009
    • 688
    I just got my head back from the machine shop, and I'm desperate to get it on the car today. I checked the back of the head and it's got one plastic piece near the back coolant hose, yet the other side is open. Here's a pic:
    Do I need either one? Or two? Am I missing one? I can't find anything on realoem...
    Thanks in advance.
    You are missing a bung, and all four of them are needed. That won't stop you from installing the head, but you can't run the engine until you have the bung.
    Get four of part #13 on http://www.realoem.com/bmw/showparts...66&hg=11&fg=25
    The best head gasket to use is the OE gasket, but a Goetz is a good second choice. Use new copper plated nuts (and anti-sieze) for the exhaust and of course new head bolts. And don't forget to use new o-rings on the top and bottom of the oil return tube. It is pretty important to chase the head bolt threads in block and blow them clean with compressed air. Oh yeah, make sure both dowels are present.
    • acolella76
      • 2950
      It's probably also worth it to mention that those are supposed to be replaced every time you change the valve cover as well. Lots of people don't do that and wonder why their valve cover is still leaking :p
      -Alex
        True! I've never understood why the bugs don't come with the valve cover gasket.
        • Andy348
          • Sep 2009
          • 688
          Thanks everyone. Turns out the VR headgasket kit came with 3 which I never saw, so I'm all good.
          I appreciate the fast responses!
          • jeffnhiscars
            • Jun 2011
            • 6011
            Note that rocker shaft end plug in the head is in backwards
            Alice the Time Capsule
            • Andy348
              • Sep 2009
              • 688
              Heres a pic, are they supposed to be the opposite way?
              Oh, and what are these? They came in the head gasket kit.
              • Keith M
                • 2338
                That is the correct installation for the plugs and those are valve guide seals in your hand.
                • downforce22
                  • Aug 2009
                  • 3193
                  Those green things are valve seals they go under the springs, between the valve guide and shaft of the valve to keep oil from leaking through. You installed the black plugs the correct way.
                  • Andy348
                    • Sep 2009
                    • 688
                    Great, thanks guys. Much appreciated.
