M20 maching specs
  • digger
    • Nov 2005
    • 6033
    clay or plasticine works. use an old gasket. no need to torque it too full specs just amke sure its snug tight with old cycled gasket ( if the amount a head gasket squashes is critical you're too close).
    measure the difference between the rocker cover gasket face and the divots see if aligns with min thickness spec in bently?
    i've never used elring only goetze and dealer (wont touch others)you can tell the quality difference between the ones in a VRS and the goetze and dealer
      For grins, and to see if it would help while still using a stock engine management system as mandated by Spec E30 , a friend used a head decked to the max and took 0.020" off the block. The valve clearance was checked with clay and found to be okay. The experiment didn't yield more power, primarily because there is no Spec E30 legal way to advance timing.
      • AlphaE
        • Sep 2011
        • 503
        nice bit off info thanks.
        i talked to Jim at Metric yesterday about cam timing. from the sounds of it, youd have to deck the block and take the head to the limit in order to make any real impact. something about the # of teeth on cam sprocket, spacing on teeth minus the amount removed= crazy small impact on cam timing.
        any other input?
        Now with 2.7i power!!!
        • digger
          • Nov 2005
          • 6033
          as little as 4* makes a difference and dont assume stock is ideal even if the change from some machining is small, there is performance to be had by playing around some....you need a dyno though
          • Ether-D
            • Sep 2011
            • 2838
            Well, to revive a dead thread. I have a new(used) head that's been decked past the divots. How far past I don't know. I'm going to clay the clearance with the normal (not thicker) gasket and report back here. What will the resulting advance on the cam timing cause? Less than ideal running? or lumpy idle or poor running etc.? I'll be getting my gasket, bolts and seals and whatnot by mail later this week...
            Originally posted by Andy.B
            I was born on 3/25…
            • digger
              • Nov 2005
              • 6033
              i always thought that reducing thickness introduces retarded timing which can hurt power everywhere but mostly at low to mid rpm
              • LJ851
                • 7918
                ^^ Use a thicker MLS head gasket to make up the difference and avoid the cam timing issues. And digger is right, the timing gets retarded.
                Lorin
                The M30 is God's engine.
                • Ether-D
                  • Sep 2011
                  • 2838
                  It must depend on where you put the belt. In my head, if you keep the timing marks lined up it wont be enough for a whole tooth to be skipped leaving a tiny bit of slack on the left side. That would allow the right side of the belt to be pulled tight by the crank, pulling the cam clockwise, advancing the timing. Right?
                  Edit: I'm not saying you are wrong, I just want to understand. I'm having trouble wrapping my brain around it.
                  I was born on 3/25…
                  • whodwho
                    • Jun 2008
                    • 1547
                    The cam would rotate in same direction as engine rotation so that would retard it.
                    My M20 Frankenbuild(s)
                    4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
                    • Ether-D
                      • Sep 2011
                      • 2838
                      Then for a stock cam gear, with a .030"+ deck on the head, which way should the cam be rotated off it's TDC mark, with the crank timing marks lined up, to get belt and cam gear to align and to get the torqier result?
                      Sorry for the run-on...
                      I was born on 3/25…
                      • Ether-D
                        • Sep 2011
                        • 2838
                        Ok, I was just playing with my spare block and heads.
                        With a head with the divots intact installed with the old head gasket, or with the .030" decked head and old gasket, there was no noticeable difference in the timing marks' relation to one another. I mean, we're talking three hairs' width. I do see now how the timing becomes retarded, because the slack is so minute, it's created on the tension side of the belt.
                        I did a few calculations:
                        1 cam gear tooth is VERY close to 5/16" which is equal to .3125".
                        My decked head has about .030" removed which is very close to 1/10th of a tooth.
                        The timing gear has 48 teeth. 360 degrees divided by 48 teeth equals 7.5 degrees per tooth.
                        7.5 degrees per tooth divided by 10 equals .75 of a degree retard on cam timing.
                        How much can this affect performance?
                        Thanks folks. Sometimes, when people like you guys are being helpful, R3V can be very informative.
                        I was born on 3/25…
                        • LJ851
                          • 7918
                          ^ According to your math the cam timing would move 1.5 degrees.
                          Lorin
                          • Ether-D
                            • Sep 2011
                            • 2838
                            Lj, please explain.
                            I was born on 3/25…
                            • digger
                              • Nov 2005
                              • 6033
                              1 degree is not enough to worry about on an average engine.
                              • LJ851
                                • 7918
                                Originally posted by Ether-D
                                Lj, please explain.
                                Cam timing is measured in crank degrees. Since the cam is running half speed compared to the crank, .75 degrees at the cam is 1.5 degrees at the crank.
                                I'll go double what digger says and say 2 degrees doesn't matter on a street engine.
                                The more important question is where did the timing start at before it gets retarded ? I have timed enough cams to know they are hardly ever where they are supposed to be exactly.
                                If you start off 3 degrees retarded, mill the head and lose another couple for 5 degrees retarded then you are giving away horsepower. Every performance engine should have it scam timing checked/ optimized in my opinion.
                                Lorin
