"Eta" to "I" Head swap questions
  • e30trooper
    • 11576
    Originally posted by MR 325
    I did forget to mention you'll want the i crank pulley and water pump pulley as well.
    Or find a belt 1" shorter to run on the eta water pump pulley.
    • Pdxseth
      • May 2012
      • 3124
      This thread is exactly what u was looking for. How much of a power increase will this give you?
      • e30mpg
        • Dec 2012
        • 187
        Copper spray on the headgasket, yes.
        Why does he need lots of RTV again?
        RTV for
        t-stat housing
        back head coolant pipe
        w/p
        intake boot repair
        rocker shaft seals and many other uses.:) You can spread some on your hand and make a palm kite with it too.
        Them paper gasket leaks on mine without a little of rtv
        • e30trooper
          • 11576
          depends what you do. I'll tell you what, my car gained the skill to chip tire shifting into 3rd gear after the headswap and a 3.73
          I have yet to be or drive another e30 that could do that.
          • JasonBates
            • 265
            Originally posted by e30mpg
            RTV for
            t-stat housing
            w/p
            intake boot repair
            I'll keep that in mind when I actually do the swap.
            I like that. haha. I honestly didn't think I would get the much of a gain out of this. But I won't complain.
            '87 325e 2.7i/5spd
            '02 Subaru outback (Still smells like dirty hippie)
            '86 635csi (Sold)
            '87 4KcsQT (Sold)
            '84 318i (Sold)
            • Aviator
              • 616
              I've been thinking of going this route myself. My lil 2.7 runs like a champ, just weak in the higher Rpms. I was also thinking of swapping an m30. But I'm really on a tight budget so this might be the way to go. Is there a bigger cam that you could run on the 885 head that will help gain some hp? And could you machine the head down a lil to increase compression?
              84 325e Burgundrot S52 M Tech 1.
              http://www.r3vlimited.com/board/showthread.php?t=250109
              • IronFreak
                • Dec 2012
                • 3702
                Yes and Yes, but if your on a tight budget....no. I'm not on a tight budget but I was going to upgrade my m20, after you price this stuff out, it makes more sense to just do a swap and start at a new baseline hp. Look at some of forcedfirebirds threads, the 885/intake was build REALLY well, unless you drop big money or go boost, it wasn;t worth it in my eyes to dump money into it for more HP.
                Instagram @rebellionforge
                • Pdxseth
                  • May 2012
                  • 3124
                  Lucky for me I have all the parts I need to do this! I just have to quit being lazy and get on it! How much boost could I safely run on this setup?
                  • IronFreak
                    • Dec 2012
                    • 3702
                    Look at kamotors setup
                      • 37832
                      A 272 or 274 cam would really wake this combo up.
                      Decking extra material off the head really isn't worth it. I'd personally rather leave as much meat on there as I could in case it needs to be decked again in the future.
                      Classic BMW Specialists
                      Grover Beach, CA
                      www.BimmerHeads.com
                      • efficient
                        • Feb 2012
                        • 3312
                        Thanks mr 325. Your info has helped.
                        Anyone know the hole size for the head bolts I want to clean up the threads.
                        • ohthejosh
                          • 4963
                          Your friend is WRONG. Please don't spread "information" if it's not true.
                          The 885 swap is VERY common on the Eta bottom end. Some people give it a bad rep but after doing it first hand myself I recommend it.
                          Thanks for clearing this up. This conversion sounds like a good start before heading into a full on 24v swap. Nice transition per say.
                          SO MUCH MORE TO DO!!
                          IG: ohthejosh
                          LEGIT CHECK ME BRUH
                          BUYER FEEDBACK THREAD
                          • kid325e
                            • Sep 2007
                            • 6422
                            I'm building one right now for my track car. I have everything I need to get it all back together but decided to hold off untill I can afford a 272/274 Cam and HD Valvesprings, as well as some Headwork. Really feel like those extra things will REALLY make this setup shine.
                            The Cam and Springs alone are looking to be around 550-800. So just getting ready to jump off that cliff here soon. Fun fun fun.
                            clutchCTRL!
                            Move with a purpose.
                            - 1991 325iX 4dr/5spd
                            - 2000 323i AT
                            2016 Mazda CX3 Sport AWD
                            • efficient
                              • Feb 2012
                              • 3312
                              why not just buy a head from myster e if your already gonna be in that deep
                              • kid325e
                                • Sep 2007
                                • 6422
                                Does his head come with a cam?
                                Sent from my GT-P5113 using Tapatalk HD
                                clutchCTRL!
                                - 2000 323i AT
