"Eta" to "I" Head swap questions
  • Pdxseth
    • May 2012
    • 3124
    #46
    That's the answer I was looking for, thanks
    • Pdxseth
      • May 2012
      • 3124
      #47
      Is all this work really worth it? From what I've read it's like +15-20 hp and a 20-40 torque loss
      Since I'm halfway into this I'm going to finish it. But seeing how this won't give me as much power as I thought. What would I gain by having the head ported and polished,bigger cam(not sure what I should get) , headers-2.5" exhaust and a chip. I'm fine with doing this stuff and I don't want to go turbo if I spend any more money on it I may as well swap something else in.
        • 37829
        #48
        We've built a 2.7i using the Eta bottom end and one of our Myster-E 885 heads.
        That thing (along with i management and a 3.73 LSD) pulled like a damn freight train.
        People don't give the combo enough credit. The particular engine we build would easily pull on a M20B25.
        Classic BMW Specialists
        Grover Beach, CA
        www.BimmerHeads.com
          • 37829
          #49
          Without throwing a sales pitch too hard here... We have 274 cams for sale for $250 shipped. Check the Parts FS section. :)
          Grover Beach, CA
          www.BimmerHeads.com
          • Chriskbmx
            • Apr 2012
            • 972
            #50
            what do i use the copper spray on? why do i use it? and how would i go about using it the right way?
            • ohthejosh
              • 4963
              #51
              How does this swap affect smog #s? Just asking for the sake of the CA folks.
              SO MUCH MORE TO DO!!
              IG: ohthejosh
              LEGIT CHECK ME BRUH
              BUYER FEEDBACK THREAD
                • 37829
                #52
                I usually do 2-3 coats on each side of the head gasket. Easiest thing it to hand it with a coat hanger.
                Will still pass with no issues if it's running good and has a nice cat.
                Grover Beach, CA
                www.BimmerHeads.com
                • JasonBates
                  • 265
                  #53
                  So I got my hands on an 885 head, and I was wondering how I should go about cleaning it and checking for anything that might be wrong with it.
                  Any ideas or tips?
                  '87 325e 2.7i/5spd
                  '02 Subaru outback (Still smells like dirty hippie)
                  '86 635csi (Sold)
                  '87 4KcsQT (Sold)
                  '84 318i (Sold)
                  • TheTacoMan
                    • Nov 2011
                    • 2308
                    #54
                    Any ideas or tips?
                    Take it to a machine shop and have it checked for a warp or cracks in the head. If you dont do this, you can run into alot of major issues.
                    • JasonBates
                      • 265
                      #55
                      Okay, I can and will do that.
                      Is there anything I should look in to replacing or upgrading while I have the head off?
                      '87 325e 2.7i/5spd
                      '86 635csi (Sold)
                      '87 4KcsQT (Sold)
                      '84 318i (Sold)
                      • MrNatural
                        • Apr 2008
                        • 237
                        #56
                        Originally posted by e30trooper
                        depends what you do. I'll tell you what, my car gained the skill to chip tire shifting into 3rd gear after the headswap and a 3.73
                        I have yet to be or drive another e30 that could do that.
                        Mine will do it after the swap. I didn't do the 885 I did a euro 320 head. It's the 200 casting with i cam and dual valve springs. Unfortunately it's leaking oil so I may have to pull the damn thing. Not sure if it's a bad hg or not...
                        • JasonBates
                          • 265
                          #57
                          More questions.
                          So, I'm doing a five speed swap the same time I do the head swap.
                          I just need to know which drive shaft and other components I need to use with the transmission.
                          I'm using a 325i transmission, going in to an early sedan.
                          I need to get this going, the auto is starting to go out on me.
                          '87 325e 2.7i/5spd
                          '86 635csi (Sold)
                          '87 4KcsQT (Sold)
                          '84 318i (Sold)
                          • Pdxseth
                            • May 2012
                            • 3124
                            #58
                            Late model or early model? I would probably start a new thread for this
                            • JasonBates
                              • 265
                              #59
                              The car is early and the trans is from a late model.
                              I kind of don't want to start a whole thread for something like this, but I might.
                              '87 325e 2.7i/5spd
                              '86 635csi (Sold)
                              '87 4KcsQT (Sold)
                              '84 318i (Sold)
                              • e30trooper
                                • 11576
                                #60
                                Depends on the year of the trans. The 86/87 etas had the larger flex dish. Im assuming you would need a matching driveshaft.
                                Pull the driveshaft from the same car your pulling the trans from.
