Valve Springs?
  • -bimmerboy-
    • Jan 2013
    • 85
    Valve Springs?
    Im doing a whole head overhaul i already have new Ireland Engineering HD rockers new head bolts new cam and new gaskets. Are the springs and valves themselves a "must replace" or am i fine just cleaning up the old ones?
  • F34R
    sLaughter
    • 12376
    Replacing the springs is wise when you do a head overhaul. Why spend 300.00 on rockers to leave the stock worn springs?
    Is this a b25 engine? 87-92 325i.
    Instagram: @BWeissLeather
    Current cars:
    ~ '87 325 M30B35 swap
    ~ '87 535
    ~ 01 540 Msport 6spd
    ~ '06 X5 4.8is
    • -bimmerboy-
      • Jan 2013
      • 85
      Yeah its the b25m20.
      • -bimmerboy-
        • Jan 2013
        • 85
        How much of a difference does it really make?
        • Me+SPEED=
          • Feb 2012
          • 189
          Google valve float or valve bounce.
          • -bimmerboy-
            • Jan 2013
            • 85
            Okay. Wow looks like i'm ordering new valve springs. Haha that definitely changed my mind thanks. Any reccomendations?
            • monsterm20
              • Jan 2013
              • 33
              VAC motorsports seems to be common. from what ive read they have great qua;ity
              • F34R
                sLaughter
                • 12376
                He is not racing his engine or using an aggressive camshaft. New stock b25 springs would be perfect for his use. Those Vac springs are to use in tracking applications where the engine would be reaching continuously high revving points.
                Order everything through www.blunttech.com, best prices around and I believe over 75.00 is free shipping. New springs will be over that. Make sure you do timing belt/ten and WP.
                Current cars:
                ~ '87 535
                ~ '06 X5 4.8is
                • SkiFree
                  • Jun 2011
                  • 2766
                  Stiffer springs for the OP would be a backwards step with what he's doing. As FEAR said, replacement new springs from your preferred replacement parts supplier.
                  ADAMS Autosport
                    • 37829
                    Used springs ARE fine if they're tested and have consistent specs.
                    Classic BMW Specialists
                    Grover Beach, CA
                    www.BimmerHeads.com
                    • AlphaE
                      • Sep 2011
                      • 503
                      This!! dont waste money if you dont have to. I tested the springs from a 87i head and they were on the money. There are specs, google it. I think its 68lbs at 1.4 inches and 164 at 1 inche. But you obviously need the means to test them.
                      Now with 2.7i power!!!
                      • digger
                        • Nov 2005
                        • 6077
                        new stock springs on a mild cam
                        good used on stock cam
                        new upgraded ones for a performance cam
                        • TobyB
                          • 5243
                          ...but if you're not willing or able to test them PROPERLY, then replacement is
                          good insurance against busticated rockers.
                          t
                          • wojtek79
                            • Jan 2009
                            • 46
                            These tools are not cheap
                            • EH Motorsports
                              • Jan 2013
                              • 19
                              have a machine shop/engine builders shop check them. its cheaper then new springs. It only takes me less then 30 seconds each to check them.
                              https://www.facebook.com/ehmotorsports
