M20 Head Cleaning??
  • -bimmerboy-
    • Jan 2013
    • 85
    M20 Head Cleaning??
    Im about to dip the head in some M.E.K. From home depot. Is this a good idea or will it damage my valve stem seals?
  • FLG
    • Sep 2011
    • 3165
    I wouldn't dip your head in anything. Bring it to a professional to be leak tested, rebuilt, and machined flat.
    Sent from my Galaxy Nexus using Tapatalk 2
    -Build http://www.r3vlimited.com/board/showthread.php?t=295277
    • jeffnhiscars
      • Jun 2011
      • 6011
      plus valve stem seals are under $1@ so replace them whenever you have the head apart
      Alice the Time Capsule
        And if the head has 100k on it, it will benefit from a valve grind. If it has closer to 200k it probably needs new valve guides and may need a new cam.
        • -bimmerboy-
          • Jan 2013
          • 85
          What is a valve grind?
          • franken325i
            • Jan 2013
            • 78
            ^its when you grind on a chick at a club........ but really they cut the sealing surface on the valve that mates to the valve seat.
            • TobyB
              • 5298
              It's where you take it to a machinist and they refresh it for you...
              maybe franken's machinist is a woman...
              t
