Head Gasket job without Resurfacing the head?
  • kid325e
    • Sep 2007
    • 6422
    Get it checked out, no sense in doing all that work to take a risk that the head isn't in the best shape!
    Get the bicycle out and ride that shit for a few days if it means doing it once, doing it right.
    clutchCTRL!
    Move with a purpose.
    - 1991 325iX 4dr/5spd
    - 2000 323i AT
    2016 Mazda CX3 Sport AWD
    • Butler
      • Nov 2009
      • 1613
      Thats why we have back up E30s man ^ :P
      -Nick
      Originally posted by 87e30
      First of all: calm the fuck down; second of all; cool story bro.
      • Dj Buttchug
        • Jun 2010
        • 7685
        no more than .006 warpage :up:
        Turbo M42 Build Thread :Here
        Ig:ryno_pzk
        I like the tuna here.
        Originally posted by lambo
        • TobyB
          • 5286
          The only reason to surface a head is if the surface is distorted.
          It can be warped or corroded. If it's not, don't cut it. They're not really supposed to be cut at all...
          However, without checking it, there's no way to know if it needs surfacing.
          Often, they don't, if they're just leaking oil. The thing is clamped to a nice,
          flat block- if it's kept reasonably cool, it can go a million miles or more, and never warp.
          The valve guides, however, poop out at 150k or so, give or take 50k miles.
          So it's worth having them checked, and probably redone, and the valves reground
          at that point.
          The machinist will check the surface, and give it a skim IF it needs it.
          Which it very well may not.
          You only know if you have a machinist's straightedge (or better) or a surface plate.
          Jeepers.
          t
          • blueapplesoda
            • Dec 2005
            • 1904
            I've lapped the head before with a large sanding block to clean off old gasket and mated with a goetze hg and new bolts (I use metric blues on the "economy" builds) and they've held well with no issues. Just gotta make sure they are flat and your strokes are even in an alternating diagonal pattern. I've done three like this, they all run fine, even under boost.
            You may want to lap the block surface too. Just make sure everything is super clean (i use acetone) before reassembly. If you use vr gaskets, it won't hurt to spray an even coat of copper gasket spray too.
            • !kid
              • 1362
              Originally posted by MR 325
              Your mechanic is a fucking idiot. Find a new mechanic.
              Even if the car never overheated or blew the headgasket there WILL be some warping to the head.
              Have it resurfaced, do it right, or don't do it at all.
              I will agree that a cylinder head will have some deflection. In my opinion, if the deflection is with in the specified range , having the head resurfaced is unnecessary.
              OP- you may need to get a thicker head gasket after you have the head surfaced.
              the next size up on the gasket is .3 mm that's .011 inches ask how much they skim off the deck of the head and that will dictate if you need the thicker HG.
              :borg:
              • AndrewBird
                The Mad Scientist
                • 11898
                What I think most people don't realize is that the head isn't warped when it is still bolted to the block, but when you unbolt it, the aluminum "relaxes" and warps. Removing the head bolts in the correct order helps with this, but you will almost always have a small amount of unevenness. A .002" cut should clean up most heads, unless the engine was overheated or something else happened.
                • -bimmerboy-
                  • Jan 2013
                  • 85
                  could a head that hasnt be sesurfaced that has recently been rebuilt cause coolant leaking and overheating?
                  • dnguyen1963
                    • Nov 2011
                    • 2651
                    If the head did not get a decking when it was put back into the engine then, yes, it could cause coolant leakage and subsequent overheating.
                    • Butler
                      • Nov 2009
                      • 1613
                      I got the head out today and after my inspection it looks "good". What ever that means, I don't have a metal straight edge that I'd call legit. I'll get one tomorrow and take a real measurement.
                      -Nick
                      • Cabriolet
                        • 9620
                        dont forget to do your valve seals while it's out
                        Much wow
                        I hate 4 doors
