Need another vac. line port on the intake manifold.
  • Sagaris
    • Sep 2009
    • 2243
    The cap on the intake manifold of my late model 325i has 1 vacuum port for the fuel pressure regulator. I need another manifold vacuum source (for megasquirt MAP sensor) and I am pretty sure I have seen an intake manifold cap with 2 or 3 vacuum ports on it from some other m20 (super eta?!?).
    I looked at one from a 325e but it had a larger hole for the cold start injector and I dont want that.
    Which years/models should I be looking at for this part? (RealOEM shows a generic intake manifold parts diagram which doesn't help)
  • travish325
    • Jun 2012
    • 1151
    Just drill a hole and thread in a 1/8 npt nipple fitting. Easy stuff
    • Sagaris
      • Sep 2009
      • 2243
      Not a bad idea, Thanks. I didn't think there would be enough meat to get enough thread for a good seal on NPT but I will take a look at it more closely if I cant source the part im looking for.
      • travish325
        • Jun 2012
        • 1151
        Ive got 2 drilled in that intake piece. It helps to put a little jb weld on the threads to seal and keep it tight.
          • 34844
          there is a peice with two vac ports on it. Not sure why, but it seemed to come on random cars, and it was always blocked off. I traded one from my buddy's car since he didn't need it. plus it doesn't look backyard hackjob mechanic.
          • E30-325iS
            • Sep 2011
            • 191
            Have a look at this thread,
            not sure if it is correct but it says the part number is.
            11611708858
              You have a hand dandy port on the bottom of the throttle body where the evap control valve goes. I'm guessing that you won't/can't implement that function with a MegaSquirt, the valve is going to do nothing.
                • 34844
                MS2 and MS3 can run the purge valve
                • downforce22
                  • Aug 2009
                  • 3193
                  Early euro cars had them for an idle throttle adjustment. They also had a vac line running to the firewall for the valve. This may be the part number from real oem 11611708858
                  The throttle body is different too. The part number I posted above is for the plate you are asking here is the entire assembly.
                  Here it is on the car with the firewall mounted control unit.
